Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. |
I've personally not had any luck tracking down suitable replacement wheels for the turntables that I have. I've even tried making things, and modifying other idlers, but haven't had useable success. Replacing the pickup with something a little easier to find is rather simple. It's not that hard to fit a PowerPoint holder or a Tetrad pickup in one of the old arms. Adjusting the tracking force is usually just a matter or adding weight to the base of the arm. But I just have never been able to find a good way to replace the idler wheel. How much does it typically cost to have an idler retreaded? Where does one go for such a service? Have people had good luck with rebuilt idlers? -Ian |
The idler wheel size makes no difference in the speed when there is a 3-component system in a phono (motor shaft, idler wheel, turntable)...what does, are the diameter of the motor shaft and the inside diameter of the turntable. The idler just has to physically fit between the two...it is just a "go-between" and has no influence on the speed of the turntable.
We do a lot of work on 40's era phonos and find that new old stock Walsco, etc. replacement idler wheels in sealed packages still have their pliability...most idler wheels that have been exposed to the air for longer than 30 yrs or so get hardened and end up transmitting motor vibration to the record resulting in excessive hum. Have not tried re-built idler wheels. We have been able to rejuvinate wheels that have dents in them from sitting against the motor shaft by chucking them up in the drill and using sandpaper to grind away the very outer edge, containing the distorted area...rubber rejuvinator can help on dried out wheels but it seems to be a temporary fix. Last edited by Chad Hauris; 05-21-2005 at 04:42 PM. |
-Ian |
tvontheporch.com |
| Audiokarma |
