Interesting - The episode 1 VHS (IMG 7801) has a very noticeable negative smear. This could be a deliberate design in the VHS machine, intended to enhance contrast of mid-size details. Can you see this negative smear on other TVs?
I also wonder if the problem set does not have a proper 75 ohm video termination and/or one of your sources does not have a proper 75 ohm termination. Last edited by old_tv_nut; 03-14-2025 at 04:08 PM. |
Your VCR and Laserdisc players could be worn out, and the JVC could also have some weak components, and it's only when two weakened devices are combined that you see the greatest issues in the raster. The DVD player is a newer device with a much cleaner signal. Either way, you shouldn't be seeing all that smearing and ghosting, and there's either something wrong with both the Laserdisc player and the VCR, there's something wrong with the TV, or both. |
Ohh, the sources... definitively.
I have a chinese S-Video VGA to NTSC that have some smearing only using with older TV's and this not appears with my more "recent" 29" TV using a jungle IC like that ("all-in-one"), aka, resolution is fine with the 29", and smeared with the olders. Then I put a DVD for testing all it's inputs and with the DVD all TV's have good fine resolution***. Is a bit odd since the 29" TV have a good/very definite and fine video resolution (I think it will not hide the aforementioned issue). Odd to explain that. ***some are better than others but all can show the chinese converter issue...
So many projects, so little time... |
Pretty much given up at this point, outside of a full tear down and recap of the TV I doubt it’s something that’s really fixable. Next step is to find an SVHS player and see if the TV likes the svideo signal any better I suppose lol. |
Conversely, if the image still looks bad, that won't really tell you much unless you can get an actual SVHS tape recorded as a real SVHS tape from a high quality source. This is also assuming the player is in good condition and doesn't have a bunch of failing SMD caps in it (as so many of them now do). |
| Audiokarma |
As I understand it none of the consumer video tape formats store video as composite. Luminance is FM modulated and color is either heterodyned and recorded directly or modulated onto a separate carrier.
The whole reason S-video exists is that if the separate y and c signals in the deck aren't combined it improves dubbing and display quality.
So I guess it'd be better to use a SVHS machine, assuming it's spitting out the raw YC info from the VHS tape and not doing any weird combining and then splitting business. |
