Old 01-28-2025, 09:54 PM
vol.2's Avatar
vol.2 vol.2 is offline
Originally Posted by YamahaFreak View Post
My apologies that my photos are too much effort to view. I've never heard of someone complaining about tapping one time to view an image, that sounds like an incredibly first world problem from my perspective.
You can also imbed with an Imgur photo, but you need to get the link to the photo and not the Imgur page.
This can be easily done by opening up the photo in Imgur and then RIGHT clicking on the photo and selecting "Open image in new tab" in most browsers.
That will open up the permalink of the photo in another browser tab.
Then you click the little photo icon here:
And then you can just paste in the permalink and the forum software will automatically embed the image. No sweat.
For example, your alligator clips photo is this permalink:
Old 01-28-2025, 10:33 PM
YamahaFreak's Avatar
<-- CSXT 6038, EMD GP40-2
Another issue I have with embedded images (as is apparent here) is they often stretch past the dimensions of the rest of the page, distorting the layout/formatting.
Sorry to go so far off-topic, though.
Sony Trinitron Fan
Old 01-28-2025, 10:51 PM
vol.2's Avatar
That's really a feature of this ancient forum software that VideoKarma still uses more than anything else.
Any recent forum package will resize an embedded image and format it within the text blocks.
I sometimes go to the trouble of resizing images multiple times in order to make a photo look good on a BB style forum like this one, but not always.
Regardless, it's still nicer for the whole flow of a thread for the images to be present with the rest of the text, and it makes it far more likely that people will respond. For reasons I shouldn't have to mention, people in general are loathe to click on random links.
Old 01-28-2025, 11:00 PM
I guess I don't consider links to the more well-known hosting sites (i.e. Imgur) to be random. I've never had issues sharing images before, so I am genuinely taken aback by the considerable aversion to tapping a single link to view a relevant image. It was the easiest way for me to share from my cell phone and I didn't think it would cause animosity to such a degree.
I would get back on topic, but I have no updates to share as of now.
Sony Trinitron Fan
Old 01-28-2025, 11:07 PM
Flicker lets you choose the resolution of the BB code image you get from them (regardless of the native size you uploaded) and you can post it in several sizes simultaneously. I find selecting 800x600 never disturbs forum width formatting, but they let you go bigger and smaller too. Smaller is great for when I make a for sale topic (my bianual ETF swapmeet threads are an example) or something I'm posting on has a lot of photos as I can get them small enough that 2-3 fit side by side without disturbing formatting.
I do almost all forum reading on my phone now (stealing a few minutes here and there) and cellular Internet here is often glacial speed trash....If someone posts a lot of links it can burn several minutes waiting for the link to load, videokarma to reload, the next link to load and so on.... It wastes enough time that doing it usually isn't worth the effort. But if they are embedded they often all load into the post while I'm reading down to it thus I'm not waiting for page loads.
Old 01-30-2025, 05:31 AM
UPDATE: I had him put the requisite 3 amp slo-blo fuse in the holder and plug it in...the set clicks once when power button is pressed, but nothing else. He says he might have felt static on the front of the tube. No weird sounds or smells, fuse intact. He wants to give up on it (not very electronics savvy) but is there a chance this is something simple or stupid? Multiple power button presses results in the same single click. Perhaps weak cap in power supply?
Sony Trinitron Fan
Old 01-30-2025, 10:40 AM
vol.2's Avatar
Zeno mentioned that this particular set tends to have a shorted flyback, and that get real soft when fixed, so it might be a lost cause.
However, if it was me, I'd probably check the all the voltages first, and I'd certainly measure any big filter cans.
You will probably need a schematic to get anywhere with it unless you stumble upon it.
Old 01-30-2025, 06:07 PM
I did make note of that, though I wasn't sure what was meant by 'getting soft'. The set at least has circuit diagrams inside the cabinet.
Sony Trinitron Fan
Old 01-30-2025, 09:19 PM
vol.2's Avatar
Yeah, that's like meaning the opposite of "sharp" when referring to the raster. Also can be more technically referred to in specific ways, depending on exactly how the raster looks "soft" such as "bloom" or "smearing." Not to be confused with screen "artifacts" like "ghosting" or some kind of pattern.
I would highly recommend just for starters to read the whole repairfaq of TV information. It's not going to cover everything, but it's a good start on really understanding different modes of failure and such
https://www.repairfaq.org/samnew/tvfaq.htm
Old 01-31-2025, 03:04 PM
A few easy things to try.
1) remove the modules & clean the contact. Check for cold joints also.
2) Look on the tuning ASSY for the standby transformer & on/off relay.
They got cold joints.
3) Post the layout chart & pics of chassis and tuner assy's
Soft tube is a low emission / weak CRT that still give a pix, but a poor one.
its usually a slow prosses that over time gets worse & worse.........
Zeno
