Old 06-01-2012, 02:24 PM
init4fun's Avatar
init4fun init4fun is offline
Originally Posted by Outland View Post
It's confusing. It's current surroundings are fine, but it came from an older relative, and I have no idea what that was like.
Judging from what I've seen from most old people, I don't like my chances.
I'll probably just take the back off outside my house, the seller has already been very nice.
The fact that your smart enough to even consider what may be living inside an old TV means you'll never get surprised inside your house by an infestation that went unnoticed . Since you will open it up outside , you can shoo any obvious critters back into the wild (?) and bring a clean TV inside . It's the people who don't give such things any thought that have problems , when their new find brings in the great outdoors with itself ......
Old 06-01-2012, 09:48 PM
if you got a compressor just take off the back loosen up things and blow the nasty all away ,outside and if looks pretty dusty were face mask dont breath in who knows what.
Old 06-01-2012, 11:06 PM
The chances are real good that there will be nothing to worry about at all. The level of filth that would be present inside would tend to be on the outside at some level. I think you'd know there was an issue.
Old 06-02-2012, 01:53 PM
Outland Outland is offline
Well I got it and took the back off.
I found a dead stinkbug and a whole bunch of bug wings (?). Oh, and an unreal amount of dust.
I used both cans of compressed air that I had, and it was still dusty. I took some pictures.
Looks like I won't be hanging on to this set.
Old 06-02-2012, 06:46 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Trust me, i've seen alot worse than that! If you really like this set and it's worth something to you,i'd hang on to it.
"IPC 610 Class E & J STD-001 Certified"
Old 06-02-2012, 07:37 PM
If I were to keep it, I'd have to get the dust out. The dust in the pictures is seemingly caked on, compressed air doesn't move it; and a lot of areas are inaccessible to me, such as the speaker cabinets.
How should I clean them?
Old 06-02-2012, 08:45 PM
lnx64's Avatar
lnx64 lnx64 is offline
You should do what I do and use a new paintbrush to just wipe off all the dust
Old 06-03-2012, 01:01 AM
lnx64's Avatar
I went from this: http://img.photobucket.com/albums/v3...n/IMG_0360.jpg
To this: http://img.photobucket.com/albums/v3...n/IMG_0403.jpg
Old 06-03-2012, 03:37 AM
YamahaFreak's Avatar
<-- CSXT 6038, EMD GP40-2
That's NOTHING compared to some of the stuff I've seen. What you have there can easily be removed with a paintbrush, old toothbrush, and damp rags, followed by a dry rag to dry.
Take a look at this video I shot of a 32" Trinitron I saved from a thrift store. This set is currently the main set in our house, in the living room armoire.
http://www.youtube.com/watch?v=eMjMGbZt0ZU
There is one particular house a few streets down from me that seems to have an endless supply of older electronics to dispose of. I have come to the conclusion that they have an infestation of German cockroaches, as most of the pieces I have removed from their curb have shown evidence of their presence. One 80's vintage Emerson 19" CRT comes to mind...this one had mostly live roaches inside. I learned quickly (and thankfully, in time) to open everything outside first!
Sony Trinitron Fan
Old 06-03-2012, 09:01 AM
mrflex65's Avatar
Like Inx64 and Yamahafreak said,assorted soft bristle paintbrushes,a good cleaner(i use 50/50 ammonia/water solution in a spray bottle.)Rags,paper towels,vacuum cleaner(forgot about the old leaf blower trick)I usually go a step further and take the chassis out for more thorough inspection(bad solder joints,lead cutting etc.)By the way, how are your soldering skills?That CRT pcb is gonna need some work and probably the main pcb as well(bad solder joints)....
Old 06-03-2012, 05:09 PM
Oh man, I knew I shoulda patented the leaf blower method
You should have seen the dust cloud that came out of the Trinitron set in the aforementioned video. I regret not filming it, but my camera probably thanks me. x3
Sony Trinitron Fan
Old 06-03-2012, 07:19 PM
Maybe I'll try to convince my tech to give it a once-over. I don't know what to touch and not touch in there.
The set seems to work fine though, how do you know there are bad joints on the PCB?
Jesus. How do you know you've eradicated them before you bring it in? I'm pretty sure they leave behind eggs and other trash.
Old 06-03-2012, 07:43 PM
mrflex65's Avatar
From what i can see,it looks like it has bad solder joints on the socket pins on the crt board (cracked solder)if you have a magnifier light or a loupe,you would see it right away.I also believe sony's were prone to horiz. output failures due to bad solder in the horiz./high voltage areas so i would have your tech go over the whole set....
Old 06-03-2012, 07:45 PM
In my honest opinion, all the joints I can see in the photos look good. If the set works well as is, the solder should be okay. As for the German roaches, it's pretty easy to find and remove all of their traces once you've completely dismantled the set. Had I not really liked this set, I wouldn't have gone to the trouble. It's a 19" Emerson stereo set, with the removable glass sheet over the CRT. Model number MS199R.
EDIT: Upon closer examination of your photos, Outland, that set appears to be a Trinitron. Worth keeping, in my book! Can you provide the model number for us? (On the back panel; will begin with KV-)
Sony Trinitron Fan
Old 06-03-2012, 08:19 PM
It's probably going to the tech anyway, I'm sure he'll be able to figure out if there are any solder problems.
I don't think the pictures show it, but Sony seems to have slapped their logo on every transistor and capacitor in the set. It's a 1988 KV-27HFR. It has a fantastic picture, which is why I picked it up.
It also has good sound, but the quad speakers are isolated, and I can't figure out how to get in there without taking all the boards out. I'm afraid there might be more surprises waiting in there.
