Old 02-14-2006, 11:41 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
I'm not sure about that, but you may be able to find lithium ion batteries that are rechargable in AA form. A little more money, but well worth the expense if you use your camera frequently.
Jordan
Old 02-14-2006, 12:45 PM
Richard D's Avatar
Richard D Richard D is offline
Until someone can change the laws of physics lead / acid cells will put out 2 volts, alkaline 1.5 volts, lithium is 3 volts per cell and ni-cads are 1.2 volts.
Old 02-14-2006, 03:30 PM
Old 02-14-2006, 04:24 PM
Richard D's Avatar
Back in the old days , 1970's 5 watt cb walkie talkies would come with two dummy batteries so when you used alkaline you would use 8 cells for 12 volts and for ni-cads you would remove the fake batteries and use 10 ni-cads for 12 volts. I guess that with 15 volts the transmitter would break some FCC laws.
Old 02-20-2006, 12:55 AM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
Back to the TV discussion.
It is a CTC 7AA and not a CTC 9. It is 21CD872. According to Ed Reital's site the set is called the Abington. It is in the early CTC 7 models. The CRT is the original to the set. It has a 1958 date code on it. I brought it up on the tester and it is good!!!! I missed out on a CTC 7 and got another the same week.
polaraman
Old 02-20-2006, 01:08 AM
blue_lateral's Avatar
Is that a glass CRT in there? I thought 7's had metal.
john
Old 02-20-2006, 01:22 AM
polaraman's Avatar
<--1956 300B
This set is supposed to have the glass CRT. I think the 21AXP22 was finished after to CTC 5.
polaraman
Old 03-11-2006, 11:11 PM
polaraman's Avatar
<--1956 300B
I had a chance to pull the chassis. Both fuses are blown and I do not want to plug it in. It is really dirty. I used the vacuum cleaner with a brush to get the dirt off. I will have to take it out side to hose it off. The set has been played with. I do not know how long ago. My test equipment is not here yet. I feel the need to get at this soon.
polaraman
Old 03-12-2006, 01:16 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
It's glass
polaraman
Polaraman, you are correct. The metal 21AXP22A picture tube ended as original equipment with the CTC-5.
The CTC-7 series originally had the newly
introduced all glass 21CYP22A picture tube.
The 21CYP22A has the two recessed high voltage connectors on the side. A resistor is used between the two connectors to reduce arcing damage.
-Steve D.
