Old 09-28-2005, 08:35 AM
outlawmws's Avatar
outlawmws outlawmws is offline
On the Run
Originally Posted by veg-o-matic
SNIP
Should I be concerned about my dot size?
veg
Size matters!
- Outlaw
Main: 9090DB, Snell Type EIII's, Marantz 6100, TEAC PD-D2500
LR: Motorola tubes, EL84 outputs, , Dual 1019 TT, Sony CDP-CE105, Wharfedale Sapphire SP-89's and a 15" GV center in an infinite baffle
Home Office: Sansui 6060, Sony CDP-C305, Original Advents
Old 09-28-2005, 08:56 AM
My CTC-5 has this dot size issue, with red being larger. I was concerned about the crt, though all 3 guns test good. Somebody is going to tell us what it means.
You can find replacement controls. For the DuMont I swapped them off of a used RCA board. They are not all the same value so you need to get the correct ones. I bet Moyers carries just what you need.
Old 09-28-2005, 12:19 PM
Red spot size will be somewhat larger in tubes where the red needs more drive than the green and blue, especially on strong white dots. I would expect the red spot gets more reasonable when you turn down the contrast. If the effect is not bad on ordinary pictures (as opposed to hard-driven dot pattern), I wouldn't worry about it.
