Old 09-17-2005, 11:02 PM
Chad Hauris's Avatar
Cost of Deoxit?
Not sure where the real best place for this is, but does anyone else in the service business use Deoxit? We are about to have to stop getting it as it is about 24.00 a can now. Nothing else seems to clean up really oxidized and tarnished contacts the way Deoxit does but it seems like every 2 months or so the price keeps going up or it keeps getting reformulated. Anyone use any other product for removing corrosion/oxidation that works good?
Chad Hauris
Old 09-17-2005, 11:16 PM
dingus dingus is offline
Banned
$9.00 a can at Parts Express.
Old 09-18-2005, 12:01 AM
bills bills is offline
Right Wing
wd-40 works well for me.
bill
Old 09-18-2005, 12:04 AM
markthefixer's Avatar
markthefixer markthefixer is offline
Tooluser
bill
Are you SERIOUS???
or just flaming???
Nothing is ever completely fool proof, because fools are so ingenious.
Old 09-18-2005, 11:05 AM
MCM electronics has it on sale. A 142 g can of D5 is $7.99 (200-040). Use source code 5A110.
Old 09-18-2005, 12:20 PM
Thanks for your replies. We prefer to use the nonflammable DN5 especially on contacts on jukeboxes, arcade machines etc where there is sparking and arcing. We may just have to use the flammable D5 for deoxidizing and then clean off the residue with a nonflammable contact cleaner.
Chad Hauris
Old 09-18-2005, 01:01 PM
MCM also had DN5 for $16.95 for 163g.
Old 09-18-2005, 02:17 PM
EchoWars's Avatar
EchoWars EchoWars is offline
Once Ran Amok in Kent
bill
-->Note to self: Don't buy used gear from bills<--
In battle, in forest, at the precipice in the mountains,
On the dark great sea, in the midst of javelins and arrows,
In sleep, in confusion, in the depths of shame,
The good deeds a man has done before defend him.
--Bhagavad-Gita
Old 09-18-2005, 03:09 PM
hpsenicka's Avatar
hpsenicka hpsenicka is offline
Moderator
I suspect that it is only flammable for a few moents after spraying.... the solvent seems to evaporate fairly rapidly, and AFAIK the DeOxit that remains behind is not flammable.
Old 09-18-2005, 09:14 PM
Right Wing
enlighten me as to why you think this is such a bad idea.
i have used wd-40 to clean scratchy pots and switches for years with great results.
and no this is not a flame.
bill
Old 09-18-2005, 09:54 PM
3Guncolor 3Guncolor is offline
Just a note on WD40... Many years ago I worked at a radio station and the oldtimer really did use WD40 to keep the pots quiet on the board it was the only thing he said would last. He had everything in first rate shape so he knew something. I have used it myself when I had nothing else. Never hurt anything but it is not my first choice.
Old 09-18-2005, 11:59 PM
Right Wing
as i said works good for me.
bill
Old 09-19-2005, 12:04 AM
Right Wing
i don't sell any of my stuff any way so what.
could be a flame naaw not a flame .
bills
Old 09-19-2005, 12:39 AM
Tooluser
Ok, I will try to be short... WD 40 is a mix of many solvents, designed to dissolve and flush out any old grease, gunk etc regardless of it's parentage.
It leaves behind some oil...
Don't get me wrong, I use it on many metallic mechanical parts, where there are no plastics, rubber or petrochemical based permanent materials involved.
I even use it for a preliminary cleaner where other stuff won't touch the gunk, but then I use another cleaner to get it out of there (fast) so that it won't contaminate or affect the properties of the CORRECT lubricant for the application.
Potentiometers are usually a resistive material "painted" on the surface of an insulating material. This involves binders ("glue"?) that were usually petrochemically based. Thus the risk of removing the resistive material, especially on older UNREPLACABLE components is unacceptably high to most of us.
The only exception would be wirewound pots wound on ceramic forms with NO OTHER materials involves, and I would still worry about the flammability of the oil left behind..
Basically If I can spray it on a match and it puts out the match, this is what I prefer to use to clean electronic equipment. When I HAVE to I use Isopoperol alcohol outside away from any possible ignition source. (fans in a room window just won't cut it for me...)
A little too careful?? mayby... but at age 22 I learned a healthy resprect for fire, and it also taught me the meaning of futility....
As to my bonafides... I am an E. Engineer by training, and I love getting down and dirty with technician type work for the last 37+ years...
(and I'm pretty darn good at it, in all im-modesty).
Old 09-19-2005, 08:10 AM
fotno's Avatar
fotno fotno is offline
Canis Major
Hey, I use WD-40 for all sorts of things, but not for electronics. It seems that WD-40 has become the duct tape of lubricants, and it does do a wide variety of things quite well. While DeOxit is not cheap, it does work better (and more safely) than anything else I've tried.
