1988 0r 89'? Zenith-Bose Digital tv
This may be a bit late for this group.I saw someone mention on the Advanced System 3 post they had Zenith modules.Model ZB2745H.I think this was the earliest year for the digital sets.Someone cut the manufacture date off the model and serial no. tag.Guess they didn't want someone else to know how old it was.I have some also but I'm lacking on this vintage set.This one has a digital main board with plug in ics.Nearly anything on the main is NLA from Zenith.A lady had this and when I fixed her early 90's Magnavox She said I could have this one.Her aunt had it and wasn't even using it.She thought she could replace her Magnavox but soon this one lost the picture.The Bose sound is wonderful.It even had the source selector accessory with it.You should see all the jacks.I'm leaning towards a main module fault but haven't dug into it yet.Has high voltage and a gray raster.You can see the AKB adjusting the gray scale when you turn it on .Also has no on screen display.Sure hope I can save it.
I saw one of these with a bad teletext IC causing no picture, or OSD. MCM had many of the ICs a few years ago, including this one. I found it by using freeze spray on the ICs on the main board. When frozen, it would work for a while. What's the module number of the main board?
Look for leaking caps and bad soldering, particularly on the IC sockets. |
Speaking of bad caps, I have a pair of Panasonic AG-1980 editing decks with bad surface mount caps on the time base corrector board (about 30 total). At least these aren't leaking, they're just high ESR. I also just got an early Sony LCD color hand held TV that has lots of leaking SMD caps.
I've seen one or two of those first generation Zenith digital sets. Unfortunately, I don't have any parts for them. A service manual would probably be helpful to you in signal tracing (not that there are many recognizable signals to trace). Zenith always seemed to forget one or two key features in those sets. I had a projection set for a number of years that had line level audio outputs so you could use an external amp, but it lacked any way to turn off the internal speakers. The last early digital set I worked on had two video inputs, but you could only switch between them via a switch on the rear jack panel. What were they thinking! |
i may have a few modules for this set. I was going thru most of mine, and wondering why I have like 8 "space phone" modules? If anyone has a Zenith with Space Phone, and yours doesn't work, let me know!
