Old 07-29-2005, 08:47 AM
veg-o-matic's Avatar
veg-o-matic veg-o-matic is offline
Huh?
Picking up the Sylvania, now I need help
Okay, I know we've been down this route before, but let's take it one more round
With any luck, I will be picking up the Sylvania 25LC1XX tomorrow. I got the SAMS for it yesterday and started looking it over.
The current owner says the set "won't focus" and was told that "some of the tube sockets are worn" (??) Haven't seen it for myself yet, but am trying to do a little background research before I open 'er up.
In the original thread, captainmoody said it's most likely the diode, and Chad said it may be the HV and focus controls.
So what would be a good first step? Other than adjusting the focus control, I mean. I don't have an HV probe ("high voltage" and "probe" are two terms I should NOT use together!) so I can't do any measuring thereof. I know if the voltage is too high the set'll send out Xrays, but I'm more worried about doing damage to the components than I am about glowing in the dark.
This diode, then. In looking at the schematic, I see a focus rectifier diode in the HV cage. This is one of several diodes with diagonal lines through the little icon, rather than just being solid. Not sure what that means, if anything.
This seems to be diode X4. I think. Still not very good with these SAMS things. I'm using 908-2, btw.
I have a couple of diodes left over from my last go-round with my Zenith roundie. I believe they're 1n4007s. The SAMS lists nothing in the "measured current" column. Are these the same as rectifier diodes?
I managed to stumble through fixing my Zenith twice. I'm hoping I didn't use up all my good TV karma.
veg
Old 07-29-2005, 09:45 AM
Chad Hauris's Avatar
You can do a check on HV regulation by measuring the voltage drop on the 1000 ohm resistor on the 6BK4 tube cathode. The tube should be drawing about 1000 microamperes with the brightness all the way down which equates to 1 volt drop across the resistor (caution: both ends of the resistor are at 400 volt potential). The SAMS should state the exact current draw on the 6BK4 for this set.
If the voltage is around 1.5 volts or more the tube is drawing too much current and HV is probably low; the HV control may need to be adjusted so the tube is drawing less current...if the voltage is only around 0.3 volts-0.5 volts either the 6BK4 tube is weak or someone has adjusted the HV so the HV is too high.
The focus rectifier diode is usually a selenium diode I believe, made up of a string of selenium pellets inside a ceramic tube. A 1n4007 diode cannot take the 5Kv or so on the focus system and will likely short...you would need to replace with a diode designed for this purpose. For the best diagnosis of HV and focus problems an HV probe will be a good idea.
Also check into a weak horizontal output tube causing weak HV and focus.
Worn tube sockets on circuit boards are the result of heat from tubes traveling downward and burning or cracking the plastic or phenolic the socket is made of. You can replace these by breaking up the burned material with diagonal cutters, desoldering the old pins, then soldering buss wire to the pins of a new good quality socket, and running the buss wire through the holes on the circuit board, to the next connection point on the trace that would have gone to the old socket.
Chad Hauris
Old 07-29-2005, 01:57 PM
There is a parts chart in Sams, look for the one that lists the diodes. It will give part numbers for X4. It will give the original Sylvania number & may give some other brands as well. From that we can find what you need. I'll give it to you if I have it.
There is no harm in trying a new horiz.output tube first, besides the high cost! When is the next hamfest over that way? You can get some good deals on tubes there. Anyway, we are going to figure this baby out!
Maybe you'll get lucky and it will use the same tubes in the hv as Anthony the Heathkit? You could just do some swapping.
Old 07-29-2005, 02:27 PM
Huh?
Ya know, B, great minds think alike! I had already entertained the idea that I might be able to do a little "creative harvesting" from Anthony, even if it's only temporary.
Horizontal output tubes are 'spensive? Well, that just figures. 'Course, the set isn't costing me anything, so I guess I can't complain.
Okay, re this rectifier diode thingie. Here are the part numbers the SAMS gives:
Original: 13-16106-1
General Electric: GECR-1
International Rectifier: 61-8969
Sarkes Tarzian: S-880
The GE and International Rectifier numbers are listed under "Rectifiers & Diodes". The Snapes-Tarzan one is listed under "Rectifiers". I'll admit this parts list makes even less sense to me than most of the others!
Do I understand that Radio Shack isn't likely to carry the diode I need? Is anyone of the opinion that replacing it would be a likely solution to the problem?
veg, the ever-confused
Old 07-29-2005, 03:05 PM
I noticed the way they list those the other week when fixing the focus on my Zenith. I don't know why they did it that way but I chose to ignore it! I'll check my list tonight for that diode. I don't really know myself how common failure of the part is but certainly if it was bad that would screw up the focus. And its an easy repair.
Old 07-29-2005, 04:38 PM
Veg-o-matic don't jump the gun on ordering parts...see what you find the trouble to be before ordering anything as there are several possible causes for the problem. Check your controls and some of your voltages and currents in the Horiz. and HV section against the sams first.
Chad Hauris
Old 07-29-2005, 09:22 PM
FYI, the Sylvania # crosses to Sylvania ECG 118 or to RCA SK 3066. I have a NOS ECG 118 if you need it.
