#46
I will look deeper into this. On my end I'm using all CRT's on the analog side and Dell S-2409 LCD @ 1920x1080-75Hz refresh. Now that you mention it the vertical detail does look like its missing one field on the final.
Going to basically start over from scratch with default settings and see how that works out. Thanks for the insight. brett |
#47
Okay so the moment everyone (almost no one) has been waiting for; Old-school U-Matic video captures from the early 1990's. Yes I have finally got everything captured and uploaded to YouTube in its native low-def 4:3 glory. Everything is direct from my old U-Matic tapes that were recorded using a JVC CR-4900U portable and captured on the Sony DXC-M3A when it had good tubes, only the night scenes were shot using a DXC-3000 and they look ghastly.
The signal chain starts with my VO-2860A feeding a NOVA 800 full frame TBC and this was run into my Sony DVW-A500 DigiBeta and chop & paste edited running the decks as a master & slave pair with all the signalling SDI then captured using a NewTek Tricaster Broadcast TC-550 which uses a mild hardware mpeg-2 then uploaded to YouTube and watered down even more. No the end video is not 4K or even 1080P but rather a testament to the resiliency of the U-Matic format. This was state-of-the-art before DVD's and I'm sure the critics will have plenty to say, don't expect an apology from me. The issues I was having earlier were the result of multiple codecs and a timing issue with my one TBC that wasn't apparent as I use all CRT's. A complete recapture and direct upload in the mpeg-2 format eliminated all of this and for a 30-something year old video it doesn't look terrible. Anyway check it out tell me what you think, flames will be ignored... or laughed at. https://youtu.be/2HlJLsBXHxQ Last edited by ARC Tech-109; 02-23-2026 at 08:41 AM. |
#48
Looks good to me.
#49
So how this all came about is I got a set of new satacon tubes for the M3A thanks to a friend at a local station and spent an evening setting everything up as best I could with the what I had, Hitachi V-089 vectorscope, V-099 waveform monitor and Sony multi standard monitor with the intent of getting some really good video to put on the Mpls cable access channel-35... that was the intent anyway. I ended up setting the green ped at 0 ire with the red & blue at 7.5 and didn't do a diff check or go over my work, all looked good on the scopes and I went with that. Next day in the car I do a quick auto black balance and everything does what it should and balanced against the green that it assumed was at 7.5 and set the levels accordingly, I didn't know this at the moment and assumed all was well until I did the playback that evening and saw my error and ended up chucking all 6 tapes into a drawer hoping they'd disappear forever... I was pi-- well you get the picture of why everything has a slight green cast.
The night shots were sometime later when I tried out a DXC-3000. I wanted to see what the night sensitivity was like, it was alright but the camera was too sparkly in normal light and edgy with proper lighting so I went back over the M3A and got it right but it ended up on the back burner in favor of a DXC-325/CA-325 package with a deep educational discount of $3500. I was originally going for an urban documentary using the angles for a more in the moment feel, actually it worked well with the fast clips and motion thirty-some years later. |
#50
#51
I might have a few more tapes shot on the M3A using the CR-4900U but the pennies were put away for a betacam and that ended up being an AMPEX branded BVW-35, if I can find them I will put something together.
#52
U-Matic is an interlaced format. If you upload it as interlaced, Youtube deinterlaces it into 30p. At best, it loses half of the vertical resolution and half of the temporal resolution. At worst, it introduces blended fields. Yours looks rather clean, but the resolution has definitely been lost, there is only one field out of each pair. The attached picture shows stairstepping on diagonals, a clear sign of the vertical resolution lost. At least there is no ghosting. ![]() You need to deinterlace with a quality "bob" deinterlacer that not only splits fields into frames, but also merges static parts of both fields to increase, nay, to preserve the vertical resolution. QTGMC is the current state of the art among free deinterlacers. Another thing about Youtube is that it honors 60p only for 720p and higher, so you need to upscale to at least 960x720 or even 1440x1080. TLDR: Deinterlace into 60p, upscale to 1440x1080 and re-upload. Quote:
2-inch was better, but it was bulky, expensive and on a wane. 1-inch was better and was quite modern, but it was R2R. Broadcasters wanted something simple, cassette-based, with quick turnaround, and U-Matic fit the bill. Betacam and M-Format eclipsed U-Matic in 1981 and left it in the dust. First generation of U-Matic SP was not as good as Hi8, but a further couple of generations were, thanks to better S/N thanks to higher tape speed. When Hi8 launched, post houses printed ads like "Shoot on Hi8, edit on U-Matic". Here are some quality U-Matic uploads (not mine):
And a VHS capture that you may like Also, if you wonder how a quality transfer of Hi8 looks, here it is, in full 60 fps glory. Hi8 has higher chroma bandwidth than even U-Matic SP, and as such, has higher chroma resolution. Last edited by DVtyro; 11-26-2026 at 12:58 AM. |
#53
It does not look bad. But it does not look correct.
Really DVtyro? So how is it that you've become this video quality authority here? You assume I don't know anything about the 3/4 U-Matic format or NTSC or how interlacing works? Seriously dude? What I find particularly amusing is how you portray yourself as an authority and critique everything with little regard for the more subtle facts of the big picture be it 4:3 or 16:9. That being said I made it clear that these were raw captures, no sweetening or other post processing to make them look better, the objective was to show the 3/4 U-Matic format in a real life setting from the lens of a 3-tube camera. If you want to compare my posted video against others that have been sweetened that's on you but again I make no apologies if they don't somehow meet your expectations as they mean absolutely nothing to me. I have been doing video production since the early 1980's and no stranger to the nuances and limitations of the various formats, you are absolutely wrong in your assertion that Hi8 has a "higher chroma bandwidth than even U-Matic SP and as such a higher chroma resolution". Both of these are color under formats with a 100 KHz chroma bandwidth and roughly 30 lines of horizontal chroma resolution despite the actual carrier frequencies being different. Debate this all you want but the fact still and always will stand. First generation Hi8 may "look" better than U-Matic but that's not the point of what I was doing and I'm at a loss as to why you brought this tangent up in the first place, the only thing you have done so far is muddy the waters with half baked and made up facts. I own both 3/4 U-Matic and one-inch Type-C format VTRs along with BetaSP, DigiBeta and HDCAM tape formats, HDW-500 editor and HDW-F900 camera for half inch and two DSR-1's docked to a DXC-D55WS and DXC-D35WS portable cameras with a DSR-50 as a 1394 feeder deck for DVCAM, all of this I've added over the decades as a freelancer so I do know what I'm doing. I also have five TBC's that handle different tasks as needed, a switcher and most everything else needed to do educational & corporate video production, if you would like some lessons perhaps this can be arranged but they will require your full attention and willingness to learn without trying to prove me wrong at every step of the way. I did a lot of educational production on top of corporate board room meetings, depositions and various other venues going back to the late 1980's when I worked in the service school for Onan corporation. The Onan Emerald RV generator maintenance video was one of my first big productions the summer of 1987. So back on point. To reiterate I was not looking to make the old 3/4 U-Matic video look like modern day, it was captured raw, edited using strictly analog methods and uploaded just as it was captured using a Newtek Tricaster Broadcast TC-550 "studio in a box" to show the format as it was then and now. If you want to stomp all over it be my guest as I really don't care, as far as I'm concerned your credibility here as some sort of all-knowing professional guru has missed the mark by a long shot. If what I'm doing doesn't measure up I really don't care. Go back and read Post #47 to refresh your memory if needed. Respectfully and Sincerely Brett Lee Last edited by ARC Tech-109; 11-26-2026 at 06:46 AM. Reason: various typos |
#54
I apologize. Quote:
The videos I linked to were meant to show how analog video converted for Youtube actually should look like. First and foremost, it should be 60p, not 30p. It is not "sweetening", it is making it viewable on a modern platform. No one watches Youtube on a CRT TV, and even if they were, Youtube deinterlaces all interlaced videos. If you want to demonstrate how good UMatic looks, you need to upload 60p. |
#55
At some point I'm going to pull all the raw tapes for a do-over, the reason being is a lot was left on the "cutting room floor" when I went for the rapid fire scenes. Looking at the finished tape on both CRT and LCD it's about the same as what you see on YouTube so I don't think a deinterlace or conversion to progressive scan is really going to make much difference but tiz' the season for editing old videos so this may happen.
I still work with the schools around the area and I often get requests to put something together using their old material, students during Christmas past and other historical things so if there's time I will rework the U-Matic tapes. Maybe recommend a deinterlacer that works with Kdenlive in Fedora-44? "No one watches Youtube on a CRT TV, and even if they were, Youtube deinterlaces all interlaced videos." Actually there is a good size CRT community that does using various interfaces be it PCIe cards with S-Video ports or the HDMI to RCA converter boxes and feeding an RF modulator so while YouTube does progressive scan to this is cross converted to NTSC or PAL interlaced video. Go check out the CRT Collective on Facebook to see for yourself. |
#56
You don't need to reprocess the tape. You already have interlaced MPEG-2, which you can deinterlace and upscale. There will be a noticeable difference in motion portrayal and in vertical resolution.
I don't use Linux, the closest I get to *nix is Terminal on my MBP. ffmpeg is multiplatform, if you run it with Yadif or Bwdif, it is a good start. QTGMC is the best free deinterlacer, it needs Avisynth to run. |
#57
I looked at those samples you provided in your earlier post and with the exception of the Hubert Kah they're really about the same as what I have here, the Hubert Kah clearly says it's a "HQ Upscale" which in my book is sweetened and not the original as it is on the tape. I also went back on my original finished tape and the mpeg-2 file I uploaded to YouTube and viewed them both on modern flatscreen (plasma) and CRT (Panasonic CT-34WX54) and they both look exactly the same as they do on YouTube thru the HDMI port so having said that I'm not going to change anything on my end as there is no need to. The workflow started with the VO-2810A U-Matic feeding the NOVA 800 TBC and this was routed to the composite input of the slave DVW-A500 DigiBeta deck so I had a reel to assemble from on the master D-500A. Once everything was done the output of this was captured using a Blackmagic design HD-SDI card in my Newtek TC-550 Tricaster broadcast then sent to my LinUX box running Fedora to be converted to a high bitrate mp4 then uploaded to YouTube and digested by whatever they use to dumb everything down. The problem I discovered isn't the interlacing so much as it is the whatever YouTube uses to upscale and render said files that isn't from some damn phone into something that's easy on their systems be it storage or thruput.
Looking at all of my videos on my channel and knowing which ones were done in what tape format or from the iPhone there really isn't much difference from the originals I have archived. Some were done in BetaSP, others in Digi and a few in 720P HDCAM which at first glance look just as good as the iPhone running in 1080P. The particular capture of the cityscapes was originally shot using a Sony DXC-M3 camera with the contour off and recorded on a JVC CR-4700U, the lack of contour is what's making the vertical detail very soft but was necessary in the day as the M3A camera was known to be very "edgy" and this would often ring later in the tape chain. No amount of deinterlacing is going to fix any of this and the real villein here seems to be the YouTube compression algorithms that are adding all the blobby artifacts... unreal. As I said before I will be re-doing this video from start to finish, the reason behind this is to add material I left behind as at the time I didn't feel added anything to the big picture however as some have pointed out in the comments and in emails numerous historical keys were also omitted regarding the former Glenwood projects that were town down shortly after I shot the tapes. FYI The Glenwood projects also known as Sumner-Glenwood built by the Works Progress Administration starting in 1938 were a slum with a very checkered history of crime & struggles on the north side of Minneapolis, they were not known for model citizens and were razed in the late 90's to build these "new urbanism" duplexes and other rentals that have also since become slums with many of the units having been condemned for various reasons. The original layout of Sumner-Glenwood was more like a prison facility and I remember kids in school referring to them as cellblocks, the entire place was surrounded by 8-foot high chain link fencing. The original name was "Sumner Field Homes" Federal project H-4201 of 1937. The historical significance as I discovered is there's very little documentation of the Sumner-Glenwood projects that isn't without some sort of political slant or opinion and most of it is accompanied by a dark news article that includes and arrest and hardship so out of respect for those who have endured these hardships I'm going to add as much of the project footage as I can before the original tapes are vacuum sealed in plastic freezer bags and put away. What I will do is experiment with various compression methods to see what can yield the best picture without all the compression artifacts and post these as "invite only" on YouTube for your feedback and suggestions. Last edited by ARC Tech-109; 11-28-2026 at 03:54 AM. Reason: typos and more typos |
#58
