JCPenney 5060VHS VCR tope loader
deleted
Deleted
Do you have an ESR meter? Maybe a capacitor is open / high ESR?
Deleted
Electrolytics can also fail short circuit and look like the ESR is low. That being said, it might be time to get a scope out and check signal flow. At that point I would probably be in over my head. I do have a scope but my troubleshooting skills are not that great. LOL However with a service manual, scope and time it's amazing what a person can figure out. Unfortunately, there are very few people who will touch a VCR and do not understand WHY we want this (obsolete) stuff working! I mess with this stuff to learn how stuff works. It does feel pretty good to bring something back from the dead.
deleted
What is molded plug disease?
Anyone know who made this..I assume its a 686-5060
Below is a troubleshooting chart from a VCR repair book. It makes a couple of good points such as will a recording on this VCR playback color on another VCR.
Sorry the image is blurry. The forum software is too restrictive on attachments! Last edited by redk9258; 05-03-2024 at 04:40 PM. |
if I utilize your assumption and look up "686-5060" in my records I find two FCC ID#'s, both belonging to Matsushita (Panasonic) as the manufacturer:
1) ACJ927029A similar models being: PV-1222/PANASONIC PV-1225/PANASONIC VH5041/QUASAR and 2) ACJ927030A similar models being: 1VCR5002/GE 855-4689/JC PENNEY KV729/CURTIS MATHES PV-1230/PANASONIC V1003/PHILCO VC2230/SYLVANIA VH5042/QUASAR VR8405/MAGNAVOX PV-1231R/PANASONIC VH5141/QUASAR Not sure why the same model returns as two different FCC IDs. Could be a typo on my part. Or maybe bad information from other sources. It was 30 years ago. Sorry. Computer (certainly not memory) says I looked at/worked on 5 of JC Penney model 686-5060 in the very early 90's. Two needed a Panasonic p/n VXP0521 FF/REW Idler (quick fixes). However, no one would approve over $76 estimates for repairs on the others... even back in the early 90's! So this may be just a cheap 2 head mono unit. Sorry I have no more help. Good luck getting yours going! |
Deleted
I wonder if somebody removed / replaced the head drum and reinstalled it 180 degrees off. A classic symptom is no color (azimuth angle is slightly different between the two opposing heads), and those black streaks are a symptom of bad heads.
Another common cause of generally crappy video in Panasonic-built VCRs are those ceramic modules. One that handles video processing is likely bad. They were about $ 40.00 back in the day. Probably NLA by now. |
I actually believe I can solve the problem. I own a PV-1220 and there is a video board near the coaxial ports. When I first bought it, it had the exact same problem. It is quite simple actually to repair. You need to locate the chroma potentiometer and spray it with contact cleaner. Spray and adjust until you have color. Also spray the channel 3/4 switch as that often becomes corroded, resulting in signal appearing and disappearing at random.
