U-Matic is an interlaced format. If you upload it as interlaced, Youtube deinterlaces it into 30p. At best, it loses half of the vertical resolution and half of the temporal resolution. At worst, it introduces blended fields. Yours looks rather clean, but the resolution has definitely been lost, there is only one field out of each pair. The attached picture shows stairstepping on diagonals, a clear sign of the vertical resolution lost. At least there is no ghosting. ![]() You need to deinterlace with a quality "bob" deinterlacer that not only splits fields into frames, but also merges static parts of both fields to increase, nay, to preserve the vertical resolution. QTGMC is the current state of the art among free deinterlacers. Another thing about Youtube is that it honors 60p only for 720p and higher, so you need to upscale to at least 960x720 or even 1440x1080. TLDR: Deinterlace into 60p, upscale to 1440x1080 and re-upload. Quote:
2-inch was better, but it was bulky, expensive and on a wane. 1-inch was better and was quite modern, but it was R2R. Broadcasters wanted something simple, cassette-based, with quick turnaround, and U-Matic fit the bill. Betacam and M-Format eclipsed U-Matic in 1981 and left it in the dust. First generation of U-Matic SP was not as good as Hi8, but a further couple of generations were, thanks to better S/N thanks to higher tape speed. When Hi8 launched, post houses printed ads like "Shoot on Hi8, edit on U-Matic". Here are some quality U-Matic uploads (not mine):
And a VHS capture that you may like Also, if you wonder how a quality transfer of Hi8 looks, here it is, in full 60 fps glory. Hi8 has higher chroma bandwidth than even U-Matic SP, and as such, has higher chroma resolution. Last edited by DVtyro; Today at 12:58 AM. |
