2 new projects? :P
First...
Another ES set! http://suzaku.live-evil.org/20261116_195822.jpg ![]() you people should know this one! And a blond! http://suzaku.live-evil.org/20261116_195855.jpg It's a moto! Motorola 21T22 (Chassis TS-531) Series strung chassis. the 21AUP4 was very weak, popped it with the rejuv, it came up a bit, halfway in the green, won't last, ordered a booster. anyone have a spare 21AUP4? :Oit has a field coil speaker :O
Motorola sure liked being weird...
![]() The high voltage rectifier is under the chassis, 1B3GT, kinda hard to get to. The set has dual selenium rectifiers set as a doubler circuit, on a 7.5 inrush resistor, using the speaker field coil as filter. The inside of the set looks like hell, as the yoke did what yokes do, the cap looks like it was hit with Duck Dodger's ACME disintegrating pistol.
![]() ![]() Unbelievable. they are all BAD All peaking coils... open. http://suzaku.live-evil.org/20261117_224457.jpg
Expected. Motorola used the same lousy infamous for being open white chalk peaking coils as RCA did on the CT-100 and 21CT55 (I own and have serviced both). I also have 2 (1/4 of the known examples) Motorola 21CT2 early color sets, and both use several of those peaking coils... I've only had a couple of their monochrome sets of the era, but I've seen them in those sets too. There's probably other brands afflicted by these coils too If Sam's gives you inductance and resistance look up the ones from digikey Miniman82 suggests for the 21CT55 or CT-100 in an old topic and grab the closest resistance/inductance in that brand and inductor family and it'll be what you need....Most sets that use these peaking coils will look OK-ish just replacing them with a jumper wire.
This moto is full of surprises, from a belt driven UHF tuner and field coil speaker, to a horizontal width adjustment that's 100% mechanical, never seen that before, screw driven gap adjustment on the flyback.
Just ordered a mess of electrolytic capacitors and peaking coils.
You had a mess. You ordered a bunch. <grin>
