Old Today, 12:10 AM
Glad you got it fixed. I've seen dirt in there before and especially at the start and end of tape contact with the head. Another thing I have found is to deep clean the head grooves (on the rotating part of the head) is to press a Q-tip straight against the groove and rotate the head backwards. This removes tape debris that has been packed in there and is used to the normal direction of the head.
Ronsonol lighter fluid works really well for removing old dirt that alcohol won't touch, and also is great for a machine that has partially are a tape and picked up some grease off the tracks and then spread it to the head.
Another key place to look is on the drum right behind the heads. Some VCR's seem to get a collection of dirt there.
Also when you run into issues like this checking for a peice of lint or dirt lodged in the heads doesn't hurt. You'll need a really strong magnifying glass to see it and a steady hand and a good pair of tweezers to get it out.
