Old 09-09-2026, 07:37 AM
CJVx CJVx is offline
7” electrostatic set deflection shortcomings
Has anyone else experienced short vertical height, only to fold over and crowd past a certain level, and not enough horizontal width, again with crowding past a certain level? Currently working on a Halicrafters and a Tele-Tone. And they both exhibit the same symptoms. The only 7 inch set that seemed to have enough to fill the screen was a Motorola VT71 that I worked on.
Anyway, I have gone through both sets, caps replaced, verified and replaced some tubes, verified filament voltage is correct in the stings etc. Checked all and replaced most resistors in the vertical and horizontal circuits with some improvement, but still not able to stretch the picture fully across the screen. If I lower the HV, this will enable me to accomplish that but now I’m only down to about 3kv and picture quality suffers.
On a variac, the picture doesn’t actually start to shrink until I lower the voltage below 90, and I don’t get any extra picture expansion if I temporarily crank it to 130 V. I do gain some brightness though.
Old 09-09-2026, 10:09 AM
Bandersen has many videos on u-tube about e-sets, I have little exp in the subject, having yet to finish the T-TONE 149 I got this year, working mostly on tape decks.
The vertical section will always be more fussy when it comes to parts out of tolerance, so it's always good to check it end to end with a very discerning eye, and if any doubt, put in new known good parts, and especially if 2 resistors of same value are linked, like are on the control plates, sample a few, like 10 and pick the closest match, it will help with linearity.
And do watch his videos, they are very helpful.
bandersentv - YouTube
Old 09-09-2026, 11:04 AM
mrjukebox160 mrjukebox160 is offline
What did you replace the hi voltage caps with? Disc caps will cause this problem.
Old 09-09-2026, 01:30 PM
Hi, I used Wima 6kV film caps on both sets
Old 09-09-2026, 04:09 PM
I never tried those. I tried Russen disk caps and they didn't work correctly. These worked but are not cheap: https://www.justradios.com/ASCcapacitors.html
Old 09-09-2026, 04:40 PM
Wima caps should be fine. I've used them in several sets.
Did you replace all the resistors in the HV bleeder network down to the vertical deflection plates?
Old 09-09-2026, 08:12 PM
that's what I got for mine, the co$t'y ones from Just Radios, I just need to finish the bloody thing, instead I have just focused on 4 tube based tape decks this year. I now have 9 Reel too reel decks, most of which are tube driven, Is that too many? :O
Old 09-10-2026, 08:09 AM
Check ohms on the verticle pots and related resistors. Wouldn’t hurt to confirm b+ voltage.
Old 09-10-2026, 12:33 PM
I didn’t replace them but they do measure within their tolerance. There has been a ton of out of tolerance resistors on this set but everything I have found has been replaced. Every resistor on the vertical and horizontal amps have been replaced, and most others on the oscillators.
Old 09-10-2026, 12:40 PM
I did replace just about all those resistors on that deflection circuits. On the tele-tone tv, B+, B++ and B- all measured within 5% of their Rider manual specs. I was kind of surprised by this, but a good surprise. I still have to verify on the Hallicrafters.
On both sets, the deflection amplifiers just seem to be running out of steam. They will amplify to a certain point until the image bunches and folds over a bit. At this point on both sets, I could get the image just to barely fill the masks, but it would be nice to figure out how to get some headroom
Old 09-10-2026, 12:57 PM
All new or known good 12SN7s I assume? :O
Old 09-10-2026, 02:15 PM
Indeed, subbed NOS in the questionable areas.
Old 09-10-2026, 05:11 PM
The only thing I can suggest at this point is, start with the voltage and resistance checklist on the SAMS, like I have for my T-Tone TV 149, and look for things that are way abnormal, especially in the sweep amp area, it might give you some clue as to what is going wrong.
Old 09-10-2026, 06:24 PM
Maybe look into any mica caps had a similar problem until I changed them.
Old 09-11-2026, 10:54 AM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Definitely check all Mica, they seem to have gotten to an age where their lifespan is beginning to fail. I replaced several in the past year or so. But be advised when you change Micas You may need to do a total alignment again as the original values are so critical in any tuned circuit.
RCA VICTOR and its dealers bring you......
