Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 12-12-2022, 03:20 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
I am pretty sure everyone has seen the film Fahrenheit 451.
https://en.wikipedia.org/wiki/Fahrenheit_451_(1966_film)
During the opening credits that are spoken, images of UHF and a few VHF antennas are seen...
Old 12-13-2022, 04:48 AM
Retired Batwings Tech
I don't know how things work on that side of the pond but UHF will never measure up to VHF for the raw coverage and penetration in the real world. I'm small town USA and ever since we went DTV and the b'cast went UHF it's been a challenge for reception. We have a few sub-channels running on ch-9 (186 MHz) that I can pick up with my amateur 2M Ringo but UHF is a little difficult despite their sub-megawatt ERP and 1470 AGL towers.
I applaud the forward thinking engineers who developed the PAL standard and 625 line system as it is far superior to our NTSC in many ways however I've always questioned the wisdom behind going exclusive UHF.
Old 07-02-2025, 05:56 PM
Colly0410 Colly0410 is offline
All 4 networks (BBC1, BBC2, ITV & Channel 4) were transmitted from every UHF transmitter AFAIK. This meant you only needed one antenna, usually pointed at the TX nearest to you. My nearest TX is the low power Nottingham relay & I can see it from my garage roof & gives a good signal, but, my antenna is pointed at Waltham a high power TX about 30 odd miles away, I used to be on Nottingham TX but nearly every time it thunders it goes off air for hours because of nearby lightning strikes, when Waltham has a lightning strike it goes off for about ten seconds then comes back on again, presume in has extra protection because it's a main high power TX...
Old 07-04-2025, 05:53 PM
Maybe so but what I do remember of the four was they were all about the same in terms of dry stuffy programming. Sorry but it wasn't anything I'd spend any time watching and that blinky 25 frames/sec made my eyes feel like two holes in the sand.
Old 07-07-2025, 04:53 PM
ARC Tech-109...After spending some time in Miami watching 60 Hz tv pictures the first thing I noticed when watching 50 Hz TV back in England was the flicker. Nowadays we have scores of channels on terrestrial digital antenna TV & I still can't find much to watch, my favourite channel is PBS America, & PBS channel 2 was my favourite channel when I was in Miami...
Old 07-07-2025, 05:21 PM
kf4rca kf4rca is offline
I remember when I started in TV we had a Saturday afternoon program about 2 guys fishing in a little boat on a river. I remember thinking why would anybody watch this crap. The answer is there was nothing else any better to watch.
Being off the air for only 10 secs is good. After we installed our back-up generator at the transmitter site, we were thrilled it only took about 7 secs. for automatic switchover. It was exciting working for a corporate engineer whose philosophy was "we were going to stay on the air no matter what just short of a direct nuclear strike."
Old 07-07-2025, 11:59 PM
That would have been the best 10 seconds for UK television. The what I remember was during the early 90's and it didn't take me long to find the power button.
Old 07-08-2025, 07:20 AM
When I goes to where I live now (2011), in the triple border with Brazil, Argentina and Paraguay, the TV stations are transmitting in analog mode yet. The Argentinian ones and some Paraguayan are 50Hz, because in these countries the power lines are 50Hz. In Brazil is 60Hz as in the USA (hence the PAL-M). I instantly noticed the flicker from 50Hz stations. 60Hz (in 480i) also produces some flicker but is less annoying.
CRT monitors capable of higher V scan ratios and hence resolution, you can apply 75, 85, 100 or even 120Hz (I have one that supports it but only at 1024x768, and supports 1600x1200 at 85Hz) and then not notice any flicker.
Old 07-09-2025, 12:48 AM
ppppenguin's Avatar
Flicker is worse when the screen occupies a greater fraction of your vision. This is simply because peripheral vision is more sensitive to movement (and hence flicker) than central vision. 60Hz may look OK when watching TV from a reasonable distance but it's horrible when close up to a computer monitor.
For interlaced pictures there is an additional 25Hz or 30Hz flicker which is hard to describe but very obvious on 625 or 525.
When I was a kid, the 50Hz large area flicker and 25Hz interlace flicker didn't bother me at all. That's how it was and most of us in Europe were used to it. In my late 20s (c1985) I got a job where I was investigating flicker on displays so I had to train myself to see it. Ordinary TV looked flickery then. We had an experimental rig that could show pictures with various scan rates and 2:1 or 1:1 interlace. 50Hz without interlace was pleasant. 100Hz interlaced wasn't too bad but 100Hz without interlace was lovely. It was also at the limit of the kit we were using so picture quality suffered in other ways. When I left that job I gradually became less sensitive to flicker again.
At the Broadcast Engineering Museum we have built an all-CRT gallery (control room in US parlance) so many of the monitors are inevitably in peripheral vision. They flicker horribly.
Old 07-09-2025, 07:45 AM
Very interesting your experience with it.
Funny... in the past, tech people worried about quality of movement/displacement of objects on display and choose/set 2ms or near it for CRT phosphours formula persistence. Times flies, and S/H (sample and hold) displays such as LCD and all variants (CCFL-backed, LED-backed etc) come in. The market flooded with these marvels but it seems only I are worrying about the horrible motion rendering of it (but all people loved the absence of flicker). No manufacturer are at least concerned with it at least in the beginning. Then: https://blurbusters.com/blur-busters...mple-and-hold/ I discovered that I'm not alone: the nature of these displays really havocs the manner that we perceive motion (blur), and then makers have spent some years in pursuit of things for mitigation it (such as flickering the back light). I prefer flicker. Less processing power needed for same motion perception (1000Hz capable video board? $$$$$). But is a headache for eg. typing a text for the Videokarma... this is the field where LCD reigns supreme due to S/H mode of working (and the individual addressable pixels).
Just in case, I don't believe we see with a 1000Hz frame rate biologically speaking, but I imagine that the motion/scan rate interacting with our own "scan" (variable for the peripheral vision, as you said), so the 1000Hz is for nulling any interaction. Proof of it is the difficult to see ficker on an 120Hz CRT. Besides other motion issues as explained in the link.
LATE EDIT: I'm maintaining some CRT monitors and the test UFO is very clear against regular LCD displays. Amazing to see. No blur in the UFO! Is possible to see it with full detail at scrolling, even at 60Hz frame rate. The CRT holds up. Only OLED with flickering can truly enters into this territory.
EDIT 2: I have a LG OLED TV that strobes the entire display once. Is horrible. Is usable only with 120Hz sources. Is different than a CRT monitor, due to the manner that CRT flickers (following the scan, not entire display once), even close watching the CRT monitor and hence seeing with some peripheral vision. Is good to save some dinosaurs to see the "real" new tech and what are really capable.
Naturally, for very slow movements, the S/H displays will not show artifacts.
Conclusion is the big size of newer TV's imposes automatically the nned of consider the peripheral vision and a eye-friendly reduction of blur.
Old 07-10-2025, 12:38 AM
The What I do know is what I saw of PAL really wasn't any better than NTSC on a 19" CRT and the program itself was nothing to write home about... I know I must consider this comes from a place where they drive on the wrong side of the road, take tea at all hours of the day and drink warm beer.
