Old 08-21-2024, 04:56 PM
Chris K Chris K is offline
Nope...not entirely. Have a very low power clean 12.5MHz sine wave. The frequency doesn't change whatever I do to the wheel and the output level has no effect on the amplitude. The meter still doesn't move into the readable zone. Going to clean some controls and see what that does.
Old 08-21-2024, 05:48 PM
No change with cleaning. When I found the blown fuse, I almost raced to the laptop to cancel my order for the $400+ sweep generator but I didn't and thank goodness. I'll see if the seller wants to buy this one to refurbish. We'll see. I guess we're back on hold again.
Old 08-21-2024, 07:42 PM
Penthode's Avatar
Penthode Penthode is offline
As I say it is the luck of the draw. As I said mine was something like $35 and I plugged it in and it worked. Even the one you bought I suspect there is not much wrong with it. Could go through it with you on another thread 😉.
Fortunately the 8601a is pretty common.
Old 08-21-2024, 08:02 PM
Penthode's Avatar
Before you give up on this 8601a, could you run through a few checks? A blown fuse suggests perhaps a power supply failure.
The 1/8A fuse looks like it was for theb-75 volt supply. You should check to ensure it is -75v and while you are at it the +20v supply.
The good thing is that after you changed the fuse, you got a 12.5Mhz sine wave. The suggests the hybrid output amplifier is good and the internal fault may be minor.
Here is the link to the BAMA stiched schematics. The Power Supply is fig_8_26
https://bama.edebris.com/manuals/hp/8601a/
Old 08-21-2024, 08:18 PM
Thank you so much. I’ll look into the voltage.
Old 08-21-2024, 08:47 PM
The -70 and +20 volt voltages are fine. It's the -6.3 volt line that's suspect. Reading only -3.7V
Old 08-21-2024, 08:58 PM
Maybe the diode to ground is bad? CR2?...at least It looks like a diode to me but where to find it on this board???
Old 08-21-2024, 09:14 PM
Or maybe the 47uf electrolytic?
Old 08-21-2024, 09:52 PM
Penthode's Avatar
With it powered on, are you able to find the correct voltages?
From your picture below and from the board layout in the manual, the edge connections at the bottom of your photograph run from 1 on the left to 15 on the right. measuer with respect to ground (chassis):
7-9 is +20v
10-12 is -6.3v
The the line pointing to the aluminum can of C12 is -75v
Old 08-21-2024, 10:00 PM
Yes that’s exactly where I read the DC voltages. The +20 and -75 voltages were perfect but the -6.3 voltage was only -3.7 V DC
Old 08-22-2024, 12:58 AM
Penthode's Avatar
Then as that is a reference voltage, something is amiss there. I will think about this.
Old 08-22-2024, 09:43 AM
It’s that voltage right on the -6.3V fuse. I don’t know if that’s before the board or after.
Old 08-22-2024, 03:38 PM
Here is a bigger view of the removed board. You can't see it too well but the resistor between the heat sinks has a chip on the outside coating that is more than just a surface mar. It reads 136 ohms. All of the electrolytic caps I can measure are about 20% high.
Old 08-22-2024, 05:32 PM
Looks like it's a 130 ohm (R4?) resistor so that's fine and 20% high is fine too.
Odd half wave power supply design with the center tap being the -6.3 volt rail.
Could be as simple as CR2 being bad. Looks like it's there for protection. Perhaps it is same to disconnect the load form this board and measure the voltages? That way you could isolate the problem to this board or what it is powering.
Old 08-22-2024, 11:37 PM
Penthode's Avatar
So if the Power Supply components are good (as I suspect they are) then one of the circuits is loading the -6.3v down.
I researched where the -6.3v and it goes to the boards listed below. The first thing I would do is to lift the -6.3v one at a time to each board until the until the voltage pops back to -6.3v:
A6 Video Amplifier Assy
A5 VTO
A4 Crystal Oscillator/Mixer
A3 Loop Amplifier/Crysatl Calibrator
A2 Divider/Divider Bypass
When you identify the board, I believe there is a good chance that is where the overall problem is.
