Old 08-02-2024, 09:35 PM
Setchell Carlson made B&W school monitor TVs I have one..Model 2100 SD. They also made industrial color monitors (also have one). I didn't know that the they made a school version of the color monitors but that makes sense.
Conrac was another brand of monitor in the tube era. If I recall they even had a color model in the late 50's or early 60's.
Old 08-03-2024, 12:01 AM
Conrac made 21 inch broadcast color monitors that were direct competition for RCA.
When SMPTE standardized the rare-earth phosphor colors for broadcast monitors, they settled on a unique batch that came from Conrac and became known as "SMPTE-C" standard. Three barrels of R,G,B were set aside and RCA made special runs of tubes to supply the broadcast monitor market.
Old 08-03-2024, 11:02 PM
Yup. I've got a conrac CYB-21 color roundy monitor (its supposedly the last roundy broadcast monitor model made) and a RCA TM-21 which was the first 21" roundy color broadcast monitor available and stayed in production long enough to be sold with 21AXP22, 21CYP22 and 21FBP22 CRTs
Old 08-05-2024, 07:33 PM
Retired Batwings Tech
I need some fresh ideas here as the video input amp is really kicking my backside. The top trace is the output of my Tricaster with a chirp pattern going into the video amp, the lower trace is what I'm finding on the grid of the 6MU8 which has been disconnected from the set video detector and has a 470k resistor to ground. On the amp board the heaters and +285V are bypassed to ground via 0.01uf ceramics but it seems like something is ringing. Here are the images of the scope, these are about the best I can capture.
Thanks in advance for any insight, I'm close but missing something I'm not completely sure of.
Brett
Deleted links from this post, images on post below.
Old 08-05-2024, 08:03 PM
I'm getting 404 file not found on these.
Old 08-05-2024, 09:19 PM
Lets try this again using imgur.com
Input board
https://imgur.com/JJnWFXd
Colorburst signal expanded on Tek 465 scope, top is source
https://imgur.com/Fag4K42
Chirp signal, top is source
https://imgur.com/2Agk7k8
Old 08-05-2024, 10:55 PM
Well, I see the thick traces on the output, but can't tell from these if it's some kind of high frequency oscillation, just lack of DC coupling, or hum.
Old 08-05-2024, 11:00 PM
Are you using the circuit in broadcast news or something else?
Old 08-06-2024, 08:19 AM
Running the same circuit in the Broadcast News article on page 18 using the 12AT7. Looked at it much closer again on the scope and it's clearly oscillating so now I get to figure out how to best neutralize this without compromising the response.
Old 08-06-2024, 10:53 AM
kf4rca kf4rca is offline
Where is the termination? On the board or at the end of the loopthru (bnc tee)?
Try other cables. Is your scope on 20MHz bandwidth?
Ground loop between scope, bar generator, and/or TV?
Old 08-06-2024, 02:05 PM
Termination at the scope with another Tee and the scope at the full 100 MHz bandwidth (tek 465 10:1 350 MHz probe), I looked at the output with my R-2670 spectrum analyzer and it appears to be oscillating around 10-15 MHz depending on the input signal so I'm going to drop a shield around the tube itself and see where it goes.
Old 08-06-2024, 05:04 PM
Push that 20 MHz BW switch in and see if it doesn't clear up. I never ran my scopes at full BW at the TV station for obvious reasons. WHY do you need 100MHz BW for only a 4.5 MHz signal???
Old 08-06-2024, 06:10 PM
Actually my career was 2-way radio and that demanded a high bandwidth scope, even with the 20 MHz limit I can still see the ripple but as it stands now I have a good handle on the issue with a shield around the 12AT7. As it turns out the reason the color was washed out was because the 1st video amp in the set was being pushed to saturation so I'm going to add a gain control pot to its grid. The amp can pass 5+ MHz to the 1st video and everything I own is previous generation broadcast be it DigiBeta, DVCPRO and Type-C so bandwidth here isn't an issue, the picture tube begins to blur at the 350 horiz line point of the resolution chart so this is about the limit of the delta gun CRT but by no means the limit of the set itself when unleashed from the 4.5 MHz trap.
Old 08-09-2024, 09:59 PM
So after a few long nights with the soldering iron and sifting thru the parts bins... I think the picture speaks for itself. 1970 Magnavox T-940 AstroSonic on composite video direct from my Sony BVH-2000 Type-C with the four card internal TBC. The audio is very strong and clear, I'm still having some instability issues from the lack of video AGC so my next project is to integrate the existing AGC into the input video amp and adding an outboard sync separator like the LM-1881 to directly feed the horiz & vert, I have a dedicated house BB gen so this would be a bonus.
Here's the screen shot of INXS direct from Type-C. Nice to actually watch something on a real CRT.
https://imgur.com/7CNslBz
Old 08-10-2024, 12:27 AM
Nice!
