Old 03-27-2024, 08:53 PM
The demods and color difference amps are very much like RCA too, except for using the 6MK8 dual pentode instead of separate X and Z demod sections.
Would have to do a detailed analysis to see if they had different color difference gains and angles than RCA.
Old 03-27-2024, 10:28 PM
Well people were blasting the "crappy Chroma demoduator" used in the "magget box" When I posted about this on FB vintage TV forum, with stuff like ," I hated the Magnavox tube sets! Chroma demoduator was crap, could not get good flesh tones."
I cant really say, but i DO like the CTC-16XL better, and this is the only and first set i have seen using a 6MK8.
Old 03-29-2024, 03:39 PM
Yes they had that reputation. There is a switch we called the brownuator SW.
If on it gives gives a brown cast to the color.You have to also watch the
plate resistors to the demods. Motorolas & Sylvanias too ! Bottom line
is turn off the auto color switches, AFT is the only one to use IMHO.
To be fair Zenith did something similar. Early " Custom" series sets
( 9-181 main board ) that replaced the S3 ( 9-160) had a puky orange pix.
Then better sets came out & had a great pix. A few minutes in the
manuals gave the reason. Better sets had auto color, cheap sets did not !
Turning off the auto color gave the good pix, turning it on gave the orange
pix. So from that point on we modified every one without auto color we sold
& the pix was as good as any.
Told the Boston service rep about it & he told me "this conversation never
happened" and DONT tell Chicago !
enuf fer now
Zeno
Old 03-29-2024, 05:40 PM
... Better sets had auto color, cheap sets did not !...
Zeno
Do you mean the cheap sets had no switch but had autocolor permanently on?
Old 03-29-2024, 07:14 PM
Exactly ! Cheap sets it was always on, better sets had a SW to turn it off.
IIRC it used a Hitachi IC & the same era Hitachis had a displeasing color palette
also. IIRC the original IC was a 221-### later was a 221-###-01
and the color problem went away.
Zeno
Old 04-22-2024, 11:57 AM
So far, knock on semi-fake wood, the Maggie has been behaving after the tube wiggle, I try it about twice a week, and so far, the loss of color sync has not come back, weird!
Dare I put the back cove on it and tempt fate! :O
Old 10-11-2024, 01:29 PM
I have finally found the source of the loss of picture (brightness ) that happens once in a very great while with this set, all this time I have been keeping the back off in hopes of nailing it down, this week I did, the brightness pot, R2 is on the front, like the color and and volume, but unlike being hard wired in the RCA and GE sets that amused bandersen a bit, this one can be unplugged, and THAT is the source of the problem, weak connection in PL3, the connector to the brightness pot on the front, I DID clean them, but this one is still giving me trouble, when I lose picture, I grab the wire, move it a bit, and it comes back.
Old 10-11-2024, 02:31 PM
Its not uncommon for the pins in the plug that have wires in them to develop bad solder joints...It's especially common in CRT heater pins to the point that they made a special repair tool to crimp the pin onto the wire...If there isn't a service reason to have it unplug you could hard wire it...last year I had to hard wire one terminal of the chromatic switch socket because it was less of a PITA than replacing the whole thing (not like I had a replacement either).
Old 10-13-2024, 02:18 PM
Zenith26kc20's Avatar
Just replaced the 150K ohm in my Maggie T-933. It went up to almost 300K ohm.
Back on and bright picture and terrible retrace. Loose 6LM8. Pushed it back in and good picture and vertical again.
Like you said, "Maggie Hell".
When I get a chance I'm going to check the 100K resistors in the back control board. Just don't trust them..
Old 10-14-2024, 07:20 AM
R101? Yeah, I replaced that w/o question cause I knew it would be bad, along with R85 & R108, a spot check of other resistors in the set found that others were still good.
