1983 RCA TV connector trouble.
Thread deleted
1) where does the other end go ?
2) does the set work ? Zeno |
Reply deleted
Beats me
![]() It may be for an unused function in an institutional set etc. Had a LOT of these apart to resolder or repair & dont remember it. You could see where it can reach with a little slack. Also look at the Sams & see if the tuner has any unaccounted connectors & where they go. If me I would try the set. BUT dont blame me if it brews up !! IIRC the chassis has pin connectors but no edge connectors UNLESS they are on small sub-pcb's. Maybe Johnct will pipe in. He has better grasp of RCA than me 73 Zeno ![]() LFOD ! |
Reply deleted
Does your set have the clock set buttons ? If not, usually a metal tab was inserted into that plug to keep random time numbers from showing up on the screen.
Reply deleted and thanks for help Zeno and Damen
Reply deleted
Reply deleted
If it's a CTC-120 chassis, that audio problem was very common. If a customer complained about it, there were 2 condensers and a coil we would change (RCA service tip recommendation). If we just noticed it when servicing the set for other issues, we would just realign the coil instead of replacing it. It used a small squared head alignment tool instead of the more common hex head one.
Reply deleted
I have this exact model RCA set and it uses the CTC-117A chassis. April 1983 date.
L201 sound discriminator coil is the culprit. |
Reply deleted
I would triple check the work you did for backwards caps and messy solder before you dig any deeper. Get it back to the state it was in before you troubleshoot
Reply deleted.
