1950s General Electric 21"
Anyone know the exact year and model? I couldn't figure anything out with what's there. Also, how do you get the front glass off to clean behind it? Cabinet is steel in black.
Genesis does what Nintendon't Last edited by pac.attack76; 04-19-2024 at 10:18 AM. |
My brother had a GE set identical to that. Bought it brand new around '55 give or take a year. Don't know the model#, but it had an unusual feature: The chassis and CRT were mounted as a unit to a plywood base and the cabinet shell and glass just lifted offa that. I remember watching 'Key Largo' with Edward G. Robinson on it.
Remove a nut and washer inside at top right corner on crt and 4 screws on bottom, then the outer body and front slide forward away from screen. Was able to clean everything. Everything seems in order except for replacing the old speaker which is deteriorated. Not sure where to find a replacement yet. Can I safely test this unit or will I need a variac?
You could use the "dim bulb" set up to safely test it. https://hackaday.com/2022/11/13/powe...m-bulb-tester/
I've got one that's a year older than yours with a series string chassis.
You could dim bulb it, but most likely there's not going to be much activity. By the look of the transformer and tube shields it's been in a wet shed for along time. Most of the caps in this set are wax paper. If it were me I'd rather even jumper in some new caps before powering up. At least in the horizontal osc / output, boost filter, vertical osc / output and bring the electrlytics up slow on a dim bulb. |
I'll look into replacing some caps before I do anything else. Wasn't in a flood. It was in storage up to the point where it was left outside in an old pickup bed. I found 4 different sets left out like this. Ones actually working. The other 3 need going through.
Genesis does what Nintendon't |
Pull the CRT's and other usable parts and st-can the rest. |
That GE is a rare model so, good luck on restoring. It generates interest from anyone *bored* with the most common GE's, me included.
A transformer-powered, dip-soldered chassis with no PC boards. 1956 for sure! Most 21" models from 57-58 year had a U1 and U2 chassis with power tuning and first generation of GE printed circuit boards. I have a 21" Motorola 1959 built in a similar manner but its series-heater, top and side panels that slip into or screwed onto a frame.
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 05-09-2023 at 12:16 PM. Reason: info correction |
One of the technicians I used to work with always said, "I'm can't see why GE is still making TV sets. They don't have that big of a share of the market."
![]() Quote:
"When resistors increase in value, they're worthless" -Dave G |
I've got it cleaned up and ready to recap. Really interested in seeing this one run again. Is there a cap kit or restoration kit available or will I have to hunt each piece down individually?
Parts list in the schematic and DigiKey? Not exactly clear on what you’re asking. The only “kit” for restoring vintage TVs I’ve seen is an eBay seller who puts together vacuum tube sets for different Predicta models.
Yeah, I just thought it would be nice if they had a collection of caps, etc. For individual sets. I'll have to make note of the ones in there and get replacements. IF I can tell what the values are.
