Thanks!
I got an X8R class one, so it at least seems like it's a better cap than the OG. I guess maybe they just hadn't advanced ceramics quite so far in 1976 and they *had* to use an electrolytic. Or maybe there's some other reason I just don't know. |
Spending 0.25c for a better part doesn't seem like a big deal, but when you are buying a million of them and buying for dozens or hundred parts for a given model times the units sold, fractions of pennies add up big time. That cap is a non critical bypass filter, literally anything would have worked. John |
I finished with the caps, and the last one changed was the big ballast cap that's in a can. It has a 470uf and a 10uf cap in it, but the schematic calls for a 470 and .022uf cap in the parts list, but a 10uf cap in the schematic. I installed the .022uf cap instead of the 10uf that was in there. Do you think that one is an issue? I have some 10uf at 250 Electrolytics I can use. The parts list calls it a mylar cap. I honestly don't know what's in the can, but my guess is they are both electrolytic in there. Thanks
I have never seen a can with different type caps so I would go
with the 470 & 10mfd. A caution on early Sony's. They would make more than one chassis for the same model number. Sometimes TOTALLY different chassii. Also supliments that almost always go MIA. So having the model#, chassis # and serial # is important. When in doubt stick with what it had especially SG613 sets ! 73 Zeno ![]() LFOD ! |
For the record, this schematic and the parts list that said 904B was 0.022uf came out of the *same* service manual for the same chassis and model. My guess was that Sony just had the cans with 10uf lying around and were like "okay just use those it doesn't matter." |
If a circuit needs just 10 more uf to run on top of 470uf, it's being run too close to tolerance which is something Sony wouldn't do, so unless they're just using a double can from left over stock, my guess is that it is a small value cap used to help snub out high freq noise. Zeno makes a great point about putting two different types of caps in one can, but we *are* talking about Sony after all!! ![]() Since 10 more uf won't make a difference added to 470uf in a bypass configuration, I'd be inclined to add a small value cap in place of the 10uf. If the 10uf is tapped on a point physically away from the 470uf section, I'd use a 10uf with a small value cap across it just to cover all bases. John |
