Thread Tools | Display Modes |
I'm guessing you've never experienced a tube TV with the Horizontal hold way off before.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 10-27-2022 at 11:54 AM. |
I think the snow indicates the video detector is OK.
I agree with Electronic M that the horizontal frequency is off. If this is due to a bad component or bad solder connection, you may not be able to get it correct with the adjustment. Once you do get the horizontal frequency correct, you will be able to see if the video is actually OK. |
You guessed correctly. This is the first tube set I've ever owned. I tried pulling the nob out 1/4 inches but it's locked at one turn. I guess this means that the cover needs to come off for the adjustment to occur. Is the stop easily bypassed with the back cover off of the television? Thanks in advance. |
It lives!!!
THANK YOU so much for helping me with this simple fix.
I carefully took the cover off, removed the knob, put the cover back on, and adjusted it successfully (almost). Here's a video: https://photos.app.goo.gl/J2RWjAgTwUAXYFRb9 I cannot get the vertical to lock completely. Horizontal seems to behave ok. Any advice on the vertical? Edit: After tweaking the AGC, the vertical locked! Thanks again! Last edited by LowHeadRoom; 10-27-2022 at 04:46 PM. |
Good example of a COMMON problem in the day. Kids would force the
H hold past the stop. Then they couldnt get it back. The vert jitters were from too much gain, thats why AGC. BTW you did a great job describing the problem. Wish they were all as well done ! Now go find a few more to work on. 73 Zeno ![]() LFOD ! |
Thank you! I will definitely be looking on FB market for more of these incredible machines.
Old tech troubleshooting kind of represents the ultimate mental challenge for me. I look forward to working on more. This community, and the community on the Antique Radio Forums have been extremely helpful. I really appreciate it! |
Having a good understanding of radio repair is a very good start to understanding TV.
It be a good idea to download a book or two about TV repair. It seems that many people are not aware of the huge amount of knowledge available online. Ask and download and you can get a library that would have cost thousands of dollars. Look for "How to Troubleshoot a TV Receiver" by J. Richard Johnson, about half way down the page, blue cover. This edition was published in 1953 so it will not contain info about transistor circuits but the basic function of a B/W TV is the same. Some test equipment is different also. https://worldradiohistory.com/BOOKSH...helf_RIder.htm Finding info about solid state radio and TV circuits is a bit harder to find. In later years basic practical solid state troubleshooting was published in magazines. Magazines are available also but the info is spread out among them. |
