Old 09-16-2021, 04:37 AM
hyperlag's Avatar
hyperlag hyperlag is offline
I like TV.
Canadian RCA CTC-39X Chassis Removal
Hello again everyone!
That last thread really helped me out a lot. I've got the power section all sorted and the odd instant on variant control figured out. Since then I've identified some caps that are probably toast and I need to replace my breaker, so I am gearing up to pull the chassis.
For the most part it seems easy to remove with most of the wires on connectors. The speaker looks to be a pain with spades on the fragile terminals, but whatever. The main issue I am having is that the bundle of wires going to the speaker panel/door with the front-picture controls are not on a socket/plug and the door they are connected to has no obvious release.
Does anyone have any tips on how to release this door without damaging anything?
Old 09-16-2021, 09:03 AM
IIRC there are 2 1/4" screws holding in the control assy.
Remove knobs then screws & the whole panel slides out.
BTW there is a tuner service mounting on the rear of the main chassis.
That blank metal arm near the power transformer is part of it.
Also has a place to nail down the control assy. Cant remember where
but IIRC it involved a U shaped bracket.
Old 09-16-2021, 10:48 AM
Yeah, do what Zeno said and the metal control subchassis should separate from the door.
BTW it tends to clutter the forum and separate important information when you start multiple topics on a single set. Please try to keep everything about this set in a single thread going forward.
Old 09-17-2021, 08:10 AM
hyperlag's Avatar
I like TV.
Thanks everyone and apologies for the multiple posts. I'll report back when I get it figured out.
