Old 07-27-2021, 08:13 PM
LukeSimon LukeSimon is offline
I spent a few hours reading research papers, articles, and patents on electrostatic lensing and especially on Einzel lenses (commonly referred to as low voltage focus) and bi-potential lenses (commonly referred to as high voltage focus).
First, the National Valve museum has scanned a great series of articles from 1950s thru 1960s that explain the basic nature of electrostatic lensing. The physical phenomenon is explained in this figure which shows the cross section of two conductors shaped as hollow cylinders with a vacuum gap between the two cylinders:
Whenever two cylinders are arranged in this manner and the difference in voltage between the two is non-zero, an electrostatic field is created as depicted by the equipotential lines. The lens is formed in the gap between the two cylinders, and its effect on the path of a cathode ray (green line) is analogous to the effect that a glass lens has on the path of a ray of light. The power of the lens corresponds to the magnitude of the difference in the voltage of the two adjacent cylinders.
This patent from Intel has a great one page introduction on different CRT focusing designs. It also describes how to use the G1 anode as an iris:
The biasing grid effectively forms an iris, which the beam passes through. This iris can be opened or closed by varying the voltage on the biasing grid.
If the biasing Voltage is brought closer to the cathode Voltage then the cathode's active emitting surface becomes larger in diameter. This active area serves as the object in the total optical System. While this voltage change allows more current to escape from the cathode it increases the object size for the optical System.
The patent goes on to describe a standard low voltage Einzel lens using the following diagram. Cylinder 20 in the figure is what televisions connect to the "focus" voltage. Cylinders 16 and 22 are connected via jumper 24 so they both have the same voltage, and they are then connected to the ultor anode using snubber springs 30. The gap between cylinder 16 and 20 forms a lens, and the gap between cylinder 20 and 22 also forms an identical power and shaped lens.
This brings me back to the goal of maximizing the sharpness of the GE Portacolor. According to Einzel lens theory, the following DC bias settings will create the smallest iris opening and maximize the power of each electrostatic lens:
  1. Set DC bias of cathodes to 270 volts (maximum possible for GE Portacolor)
  2. Set DC bias of G1 to zero volts (minimum)
  3. Set DC bias of G2 (screen) to 670 volts (maximum)
  4. Set DC bias of G3 (focus) to 0 volts (minimum)
This voltage setting will likely have black levels that are incorrect. So starting from those "max lens power" voltages, if brightness is too high, I will lower G2 voltage until brightness is correct. Otherwise, if brightness is too low, I will raise G1 until brightness is correct. The electrostatic lens theory stats that as lens power is increased, spherical aberration is also increased. This is why increasing the G3 focus voltage above ground potential may be necessary for maximal sharpness. So the final step for calibrating the GE Portacolor's sharpness is to, starting at zero volts, increase the voltage of the G3 anode until the picture has maximal sharpness.
Doing this will require modifying the GE Portacolor to add 2 additional pots. One for controlling red G1 voltage, and the other for controlling the G3 focus voltage.
