#31
I try to use Xicon brand carbon film 1W resistors. They cost less than 4 cents each when buying more than 10 at a time. I'll typically buy 25 or 50 of each value that I need. The 2W and 3W resistors are again Xicon and are metal oxide and the 2W cost about 8 cents and the 3W costs about 10 cents. I try to use Nichicon E-caps with 105C temperature and 10,000 hour ratings. Mouser does have a Will Call that means I can call in an order and it'll be ready in an hour to pick up. No minimum purchase too. They're great people there. Last edited by Crist Rigott; 02-28-2020 at 02:36 AM. |
#32
![]() but that's another story.
#33
The great thing about Mouser and DigiKey is that the filtering process opens up a world of info. I always look for high temp, high hour, and depending on circuit, low ESR and/or high pulse. .20c difference in cost may be nothing in small quantities, but when you're buying a million of them, we can see why manufacturers spec a lower rated component when they can get away with it. In these low frequency applications like TV and radio, just a good quality 105c high hour cap is perfect. I always use Panasonic caps when they're available. I've spent a lifetime in consumer electronics and have rarely seen a Panasonic cap bail. John |
#34
Lately I tend to use the maroon Panasonic caps for straight recap work and save the yellow caps for restuffing (where they are better spatially than the Panasonic caps).
#35
I re-stuffed the 3 E-Caps C1, C2, and C3 in my usual manner and installed them into the chassis. I'll buff out and install the cans later on.
![]() ![]() ![]() ![]() ![]() I then decided to tackle the front panel controls. Each control was removed, checked for value, checked for dead spots, cleaned, lubed, and the shafts were then polished and a coat of clear from Mohawk that is safe for brass. I then worked on each terminal strip near the controls. The tuner shaft will be polished when I work on the tuner at a later date. ![]() ![]() ![]() ![]() ![]()
#36
I like your can restuffing technique. It's different than mine which I will post at some point. I only restuffed paper caps on one radio because the customer wanted it, but restuffing the cans is the best option because it doesn't add any clutter underneath the deck, and if someone is using a SAMS or another identical chassis for reference, they still look the same.
But we have the same issue: what adhesive to use for bonding the cans back together? I've been using two part epoxy, and indeed, it will be decades at least before they would ever need to be addressed again, but I was thinking about using a high temp hot glue or even hide glue. In other words, something that can allow the cans to be taken back apart with heat. Oh, and your wiring is FAR too neat!! ![]() John Last edited by JohnCT; 03-01-2020 at 03:52 PM. |
#37
I don't glue the cans back on. I just slide them back over the plastic sleeve. It's a slight friction fit. That way, the cans can be simply removed by lifting them off. |
#38
John |
#39
The white PVC sleeve is epoxied to the base of the capacitor.
#40
Here is a link that goes into detail of how I restuff E-Caps.
http://www.videokarma.org/showpost.p...1&postcount=46 |
#41
I then did the terminal strip near the CRT.
![]() ![]() I then started down the left side of the chassis which is the IF strip and finished up near the power transformer. ![]() ![]() ![]()
#42
Were the original box caps actually micas, or papers that looked like micas? Is there a way to tell? I have a 51 Andrea with a bunch of the beige "micas" that look like those in your TV and I'm not sure if they actually are mica or not.
John |
#43
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 03-03-2020 at 01:46 PM. |
#44
John |
#45
