Old 10-31-2019, 03:00 PM
starbond starbond is offline
Another update, i finally got my hands on the frequency counter, and have been testing out the various crystal frequencies. Looks like my problem spot is the 4.27mhz crystal on the color/rec board. its pretty badly out of spec, and no amount of screw adjustment will get it close. But it seems nobody makes that frequency anymore.. so am I out of luck?
Old 10-31-2019, 03:29 PM
The ham radio community often has need for uncommon or unique crystal frequencies, and there are custom crystal makers that cater to them....they can probably help you.
Old 10-31-2019, 04:09 PM
I see the exact frequency is specified in the setup instructions as 4.267200 MHz. If you do order one, be sure to specify the full accuracy and not just 4.27.
Can you post a clear pic of the schematic of the circuit that uses this? Curious as to what it does with such an oddball frequency.
Also strange that your reading is off by almost exactly 1 Mhz. Can you find the crystal and read what frequency is marked on it?
Old 10-31-2019, 04:18 PM
Actually, it's probably the oscillator that beats the color subcarrier down to a lower frequency (~690 kHz) for recording, but why it is critical in the input monitoring mode beats me, unless this machine operates the full record and playback electronics end to end all the time.
Old 10-31-2019, 07:01 PM
At this point I dont know what else could be causing my weird banding on the picture, so far this is the only thing I've measured with the frequency counter that's out of spec. I've even replaced the bad 47uf cap, and the 2SC828 transistor as a precaution, neither which had any effect on the crystal. In fact I went to measure it again just now, and its reading 2.8 mhz!
Old 10-31-2019, 11:11 PM
Again, can you post a clear pic of the schematic of the 4.27 MHz oscillator, and indicate where you are connecting the counter? Putting a 0.001 disc cap in series with the counter lead might be a good thing to make sure you aren't loading the oscillator.
Old 11-01-2019, 12:33 AM
I posted the schematic in the last pic but I'll isolate it down. Unfortunately whoever scanned this schematic did so at a terrible resolution, and I haven't been able to find a better one since.
Frequency counter is attached to TP204,the 4.27mhz crystal is X201. The adjustment screw is C219.
Old 11-01-2019, 11:20 AM
OK thanks. The counter should not be loading that test point significantly, so it seems the crystal/oscillator really is the problem.
Old 11-01-2019, 11:35 AM
Thanks for verifying. I am having a hard time finding a crystal with the correct frequency, unless I want to special order and pay $$$$
My question (in general) is that if this quartz crystal was so important to color syncing in vcrs and tvs, why is it not as common as the 3.57mhz crystal?
Old 11-01-2019, 11:50 AM
I believe different VCR systems used somewhat different color-under frequencies. VHS crystals would be the most common. Also not 100% sure, but likely that different frequencies were needed for PAL and NTSC.
Old 11-01-2019, 02:33 PM
Thanks TV Nut. The closest crystal i could find is 4.2944mhz. Not great. Do you think the little 30pf cap could tweak it down to 4.2672?
https://www.mouser.com/ProductDetail...XTAL035831BULK
Old 11-01-2019, 02:46 PM
NO. A crystal oscillator that could be detuned that far wouldn't really be dominated by the crystal resonance, and might oscillate at an unstable crystal mode as well. An extreme value for detuning might be 1 KHz, and that much would never be designed into an oscillator meant to be a reference, only into a voltage controlled one meant to track a broadcast or tape playback signal.
Old 11-01-2019, 03:14 PM
OK thanks for that. I will go back to the hunt. Are you saying ONLY a 4.267200 crystal EXACTLY will work, and nothing out of that range will be acceptable?
Old 11-01-2019, 06:38 PM
... Are you saying ONLY a 4.267200 crystal EXACTLY will work, and nothing out of that range will be acceptable?
Yes. There's a outside possibility that an off-frequency crystal would allow the VCR to record and play back its own tapes , if the under-color frequency is all it affects; BUT even then the VCR would not play or record tapes compatible with VCRs using the standard crystal.
Old 11-04-2019, 10:24 AM
So I have some great news. Firstly it turns out the 4.27mhz crystal WAS OKAY. The counter i was using was giving bad values. So the error was somewhere between the color circuits and the color output.
I hooked up my scope leads 1.) to where the recombined NTSC color was coming out of the color circut and 2.) the INPUT where the signal generator was coming to the unit. Both should be the same waveform and it was..so I started looking at the EV color play board.
Due to some dumb luck I started tweaking one of the screw adjustments (L509) all to the way to max level, and suddenly BOOM, color! Its not perfect, as when I twist L509 to make color on the video tapes, the MONITOR colors are still wrong, but when I twist l509 to make the color bars correct, the tape color goes back to rainbowing. So tonight I have some work to do on the adjustments, but man it feels good seeing color on these tapes (even if they are taped in the 80s from a source with high generation copies)
