admiral crt
Hi there DO Not STOP Hitting the center of the crt cap you will brake the crt
use a very small flat edge srew driver and insert the small flate blade between the crt cape that has wires plug and the crt plug and wiggle the screw driver very carefully or you could brake the cap on the crt. be carfull the 7jp4 is rare and hard to replace i have 8 admirals tv all start with 19a1 or 19a12 and 19a15 Do not brake the center of the crt key way there a glass steam inside the cap good luck clifford |
