Old 01-24-2019, 10:09 AM
cparsons2391 cparsons2391 is offline
Curtis Mathes 4224
I am needing help finding any info and a schematic for this tv. I did not find a chassis number, but there is a lot of dust and some corrosion. I am hoping someone recognizes the tv.
Here are some photos: https://photos.app.goo.gl/VWgJvQN8HxAZpdXH6
The CRT is not busted and the filament does have continuity. I am going to put the base back on soon and test the CRT.
Thank you!
Old 01-24-2019, 11:29 AM
Notimetolooz's Avatar
You really need to find the model number or chassis number to work on this. You need a CRT tester to test the CRT because the chassis is probably not working well enough.
EDITED: Sorry I mis-read your post. I didn't find any Curtis Mathes 4224 at the SAM site.
Old 01-24-2019, 11:38 AM
I do have a CRT tester. That was my plan for testing the CRT. The model number on the TV tag is 4224, the issue is that the corrosion has covered/removed the chassis number. I was hoping to figure out which sams would have this tv if someone could recognize it.
Old 01-24-2019, 11:52 AM
First get some date codes off some ORIGINAL major parts.
Then find SAMS for similar models about 6 mo to a year later.
If you have access to a collection thats great. If not someone else
may or you may find them on the internet. You will find a similar
manual most the time.
Old 01-24-2019, 12:35 PM
If it is 62 or older I can pull folders and take pictures of the tube charts to help ID it...
Old 01-24-2019, 01:23 PM
It's badged as "Mathes" instead of Curtis Mathes so it's late 50's or early 60's.
They were built rather well then.
Old 01-24-2019, 03:01 PM
Thumbs up
I figured it was late 50's. I did think it was odd that it was marked Mathes, but the tubes in it were Curtis Mathes tubes. I will attempt to find a date code tonight.
I really do appreciate all of the input and help so far!
Old 01-24-2019, 06:46 PM
The original Curtis Mathes tubes have date codes of 1959.
Sams Index says:
1959: Folder: 468 set 1
1959: Folder: 465 set 6
Old 01-25-2019, 11:50 AM
Sams Index says:
The model 4224 is probably a cabinet number difference.
Sams shows a 4200 series, folder 506.
Old 01-25-2019, 12:57 PM
I do really appreciate all of the help!
I have ordered two different Sams.
The first sams covers chassis models: 1121, 2121, 3121A, 5521A
These models use a 21CBP4A picture tube. Which is what mine has.
The second Sams covers chassis models: 7323, 9323
These models use a 23CP4 picture tube.
Both of the photos on the front of the Sams shows only 5 knobs on the front whereas mine has 7, but I think these two Sams will get me started.
Old 05-06-2019, 08:01 PM
For anyone who is interested I thought I would post an update. The tv is recapped and working! Someone had tweak all the controls so I did a rough alignment.
Sorry for the terrible photos. This will make a great workshop tv.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 08-08-2019, 08:47 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Interesting early Mathes TV set. They didn't make too many of these sets before the change to Curtis Mathes. The Mathes company made radio sets, and radio/phonograph consoles before they made a TV set. A rare bird.
Old 08-08-2019, 08:49 PM
Mathes began by making the Mathes Cooler, a well known electric fan in a wooden case with louvers. From there, Mathes branched out to making Radio sets, then HiFi console radio/phonograph combinations, and then televisions. And a little bit later, renamed the company to Curtis Mathes. Which is what most people know them best as.
Old 08-08-2019, 09:51 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Awesome TV and the pic looks great!
Now put those bumblebees and black beauties on ebay
Old 08-09-2019, 08:35 AM
I recently got a box of channel knobs with a few of those CM channel selector knobs in it, and now I know what they go to.
