Old 05-16-2018, 06:09 AM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
1955 Motorola 17T20
I got this set for free, just had to drive 75 miles both ways to get it but for free why not. I got this set home and powered it up, the tubes light up but no HV or sound, i knew then this set had no B+ so i pulled the chassis and found many a problem like falling apart sand resistors, fried and cracked resistors, split bumblebees and i think the selenium is bad but not sure at this moment. All the caps and some resistors will need to be replaced obviously. I haven’t checked the tubes yet because my tester went out and I don’t have a spare, but luckily a stereo store near me lets you test tubes for free and there is an upcoming hamfest i’m going so i can hopefully get a new tester.
Your good times will bring me down
Old 05-16-2018, 06:11 AM
LADR's Avatar
Местное и дх радио
Not in bad shape
File Type: jpg F37DF6DB-1290-4178-8560-5A6AFBEF7AC2.jpg (73.0 KB, 147 views)
Old 05-16-2018, 11:25 AM
Don't bother testing the selenium, just replace it with a 1n4007.
Old 05-16-2018, 11:38 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Agreed...I do that on all old tweed Fender amps.
Old 05-16-2018, 12:40 PM
The tubes light so the glo-bar resistor must be ok. Just check the sand resistors to see if they're still good for now! I've seen a few of them with cracked resistors. You probably need a schematic to determine resistors that are burnt beyond recognition. Of course, you have to change the split caps.
No B+, check the plug in resistor on top of the chassis, usually a 7.5 ohm, 5 watt. Make sure the speaker is plugged in, as the field coil is the B+ choke.
Old 05-16-2018, 10:47 PM
LADR's Avatar
Местное и дх радио
Thats what i’m going to do.
Old 05-17-2018, 11:07 AM
I always do a preliminary assessment of the condition of the set, by just replacing the obvious defective parts and checking the CRT.
A schematic is generally needed and makes it easier. I don't do wholesale changing of parts until I know what's involved. I still do it in stages.
Motorola made about three years of this chassis. They were always easy to get going, but that was when they were less than 10 years old.
Old 05-17-2018, 11:13 AM
maxhifi's Avatar
maxhifi maxhifi is offline
This looks like the American cousin of the Marconi I'm working on right now, 17" series string set, with a half wave selenium rectifier? What picture tube does this one use? Look forward to following this project.
Old 05-17-2018, 09:42 PM
Even though, it's not my set but I know it enough, from experience. It uses a 17HP4 CRT and a voltage doubler for higher B+. The tubes are in a series-parallel configuration, where the set you have is a newer model, using only one 600ma series string. That's the way, the US designed sets progressed to.
Yours is very similar to the US designs.
Old 05-18-2018, 10:15 AM
maxhifi's Avatar
You nailed it there, I don't want to throw this thread too far off topic, but it would sure be interesting to understand the progression in circuit design from the RCA 630 to say, the Philco Predicta or maybe a bit later.
Old 05-18-2018, 03:59 PM
LADR's Avatar
Местное и дх радио
The Crt is a rebuilt 17HP4 and it checks way into the green and has 10 original tubes and 6 replacements, so this set is sorta kinda low hour.
Old 05-19-2018, 04:40 AM
LADR's Avatar
Местное и дх радио
This set was made August 1954
Old 05-19-2018, 02:51 PM
LADR's Avatar
Местное и дх радио
Top and bottom view of the chassis
File Type: jpg E6166608-5EB0-492E-AA68-0B9D159647BD.jpg (125.0 KB, 44 views)
File Type: jpg CB8E2959-C6B9-4F5F-A712-71162FBE0C3F.jpg (83.5 KB, 49 views)
Old 05-19-2018, 03:18 PM
maxhifi's Avatar
Looks really nice, I look forward to seeing how it works!
Old 05-19-2018, 03:51 PM
I parted out a similar vintage moto monochrome with a weak CRT and a ruined cabinet...I still have most of the chassis and may be able to supply parts if needed.
