Old 12-20-2017, 09:42 AM
radioal radioal is offline
Emerson used a fabric covered vinyl insulated wire since the late 40's, perfectly safe.
Some manufacturers used an asbestos pad above the 50C5 tube, as it runs so hot and could discolor the plastic cabinet.
If you run into that type of insulation in a cabinet, soak it down thoroughly with dish detergent and scrape it carefully as not to get the fibers airbourn.
As to why your clock-radio has no snooze bar-. It's the "kitchen" model. Some manufacturers of this era produced both bedroom and kitchen versions of the same clock radios. Often the kitchen models also had a courtesy outlet on the back so you could plug in a coffee pot and have it automatically start the next morning.
Sent from my Nexus 5X using Tapatalk
