Old 04-10-2017, 06:19 PM
... They stated that you had to clip that pin off the tube.
Use a needle file to file it off. Trying to clip it off with wirecutters will likely break the tube's base, letting the vacuum out.
Old 04-10-2017, 07:07 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
Don't need to worry about cutting a pin. I have some 1L6 tubes.
The previous owner had put a 1R5 in place. Oddly, it can oscillate at a higher frequency than my T/Os with a 1R5 and is more sensitive.
Old 04-10-2017, 11:11 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Speaking of 1L6 tubes, How do the solid state replacements compare?
SR
Old 04-29-2017, 10:09 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Yikes!
Dude. Hook 9V to the wrong spot in the string, and you can definitely blow a filament or two. Or three. (That's assuming your 9V is a 'hard' source like a battery, wall wart etc.)
I meant to connect to where the battery hooks up... not in the middle of the string O_o
