Yeah, they did eat flys and jugs too. Getting them thru warranty was always a challenge, but that was par for the course for with all color brands. Five years was considered reasonable lifespan for a color set.
With RCAs we routinely changed the power xfmr primary to the 'high line voltage' tap, to drop the 6JE6 cathode current a few notches, and dipped the efficiency coil. Surprizing how many were not on 'true dip'. Last edited by old_coot88; 02-21-2017 at 12:49 PM. |
It seems that the 25A was the only RCA chassis, that used the solid state audio board. Most of the 25's I worked on had the tube audio.
I think RCA quit using it because it was more trouble prone. I have a year newer CTC28, that uses a tube audio. |
The CTC-25 that I had, years ago, was identical to the one Tim "Kamakiri" has pictured! It had the fancy speaker on the left side of the CRT only, different model from Universal Dave's set, which has the fancy speaker on both sides of the CRT!
[B]"Bee care-eh-full to don't broke thee pic-sher tee-yube!" :-) |
I got bored today, so I did a little dynamic convergence on the Beauchamp. I'd say turned out pretty darn good.
The Dumas.
