#31
Your Buick should get low-mid 20's mixed driving. My squaw
had a '99 LaSabre & got mid 20's. She bagged a dear so only got abt 150K on it. Never needed "tune up" type stuff but that engine was a leaker ! Assuming 18 gals that would give about 400 miles. Either engine isnt running right or cat is plugged, O2 filthy etc. IF you need a cat price it at a custom exhaust shop. One on my crown vic was rattling & got it changed for <$250. Whatever u do be damn sure its running right when done or you will wreck everything again. 73 Zeno ![]() LFOD ! |
#32
For snow driving most cars if you put it in "2" you lock out
low gear & make it much easier to get traction & avoid downshifts going up hill. On RWD it also eases you down hill with very little braking. Just avoid sudden downshifts or you get spin out. With FWD there are a few more rules. Biggest thing with FWD is if you HAVE to go out in snow storms get snow tires. You may not need them but it makes a HUGE difference. My 1st FWD car was one of these. https://www.cargurus.com/Cars/1972-O...ureId:11444845 About 3000 lbs sitting over the front wheels made it go in snow even with bald bias ply tires. Added snows the next year & you could go almost anywhere a big 4WD truck can. 73 Zeno ![]() LFOD ! |
#33
One of my dream cars (among many) is a Jeep Grand Wagoneer. My favorite SUV ever. I would love to have one, but they're getting so darn expensive. Put snow tires (or chains) on that, and you can go anywhere. Only problem is that since Grand Wagoneers are getting so rare, you would have to be careful of all the road salt.
#34
Before the Chevy 283 V-8 there was the 265 V-8. And before FORDs' 289 V-8 there was the 260 V-8, don't know what Chrysler had before the 318. All the best,Tom.J
#36
Yes I'm only 28 years old, plus ontop of that my mom's dad's family were into Mopar because my grandfather's dad owned a Chrysler dealership out in Myerstown, PA years ago so I'm not as familiar with the GM and Ford Engines but as far as I know Chrysler never had a Small Block V8 engine smaller than the 318 because the 318 was their workhorse engine for years (besides their Big Blocks like the 360, 440 and the 426 Hemi) I know that Chryler's original Hemi which came out in 1955 with the first Chrysler 300 was a 331 CID engine, and apparently according to what I was reading GM at least (don't know about Ford) was trying to limit its V8s to less than 400 CID which is why GM had their V8s in the 200s and 300s as far as CID went whereas Chrysler didn't operate with such limitations which is why they had two extremely powerful V8 engines at over 400 CID (the 426 Hemi and the 440). So that's what I know.
#38
Chrylser only ever had the 318, because it was an engine that just worked and it was the workhorse engine that was put in just about every Chrysler car that wasn't a muscle car (like the New Yorkers, Newports, the Darts, the Diplomats, the Furys, Volares, etc.) My guess is that because of the fuel crisis of the 1970s GM and Ford decided to downsize their V8 engines whereas Chrysler didn't and that probably explains why Ford and GM had such small V8 engines compared to Chrysler, either that or they just were wusses and just weren't daring enough to try and experiment with engine sizes that went over 300-400+ CID like Chrysler did. Either way, its not really something worth arguing over.
#39
The smallest V8 that I recall was the aluminum 215 Buick, Oldsmobile, Rover engine of the early 60s. Fun to work on as one could easily pick up a bare block and set it on a workbench. jr Last edited by jr_tech; 01-15-2017 at 07:36 PM. Reason: add info about 215 ci V8 |
#41
Cadillac had 500 CID engines in the late 60's and early 70's...I've been tempted to buy Eldorados with that engine. If you did not have a V8 back in the day it probably seemed a bit cheap....I'd imagine the small ones were the fuel savers for the people that did not want to be accused of being fuel savers.
#42
The 215 aluminum Buick motor was a V-6. Buick did have a 300 V-8.
#43
https://en.m.wikipedia.org/wiki/Rover_V8_engine jr |
#44
I read a fascinating article on a car site (wish I could find it) a few months back on the engines of GM's 60's 'Senior Compacts'. That explained the history of that engine well...In that block's original form it was an aluminum V8 that was shared (with tweaks) between divisions of GM...There were casting issues with the aluminum that resulted in reliability issues. An engineer at Buick told his boss that he could saw off two cylinders from the V8, switch to a normal cast iron block, do a few other changes and make a V6 that would be better than the V8 it was derived from. After GM was done with it Jeep bought it and used it (due to it's power and reliability), Buick later bought it back from AMC/Jeep in the 70's and kept improved versions in production through the opening years of the millennium. The aluminum V8 was popular with speedboaters and when Land Rover representatives were in the states they got interested in the engine and bought the rights to it, and used it for a long time.
#45
