Old 03-30-2005, 08:45 AM
newtvdude
Guest
Posts: n/a
Unhappy Need a push button bank for an RCA
Hello TV friends
I need a four place push button bank for the RCA console that I have. It is the selector for the TV/Tuner/Record Player that is located next to the tuner, and when you push one the others pop up. I hate to put singles in and risk a short and/or fire. I would consider purchasing the entire module as well. I found some surplus ITT switches, but they were too wide (between the switches). Any help to locate this would be greatly appreciated.
Thanks loads
Old 03-30-2005, 07:19 PM
jstout66 jstout66 is offline
Get the chassis number and or part number. Moyers electronics would most likely have that part, but they will need the chassis number. If you have the Sams you can get the part number, however they may be able to look it up. http://www.moyerelectronics.com/
Old 04-01-2005, 10:01 AM
newtvdude
Guest
Posts: n/a
Smile
I sent them all of the information that I had and they did say they have the part. I sent them the money and I'll let you know if it is the correct part. Thank you very much for the helpfull information!
Old 04-01-2005, 11:05 PM
no problem! I've never had a problem with them and they ALWAYS seem to have those obscure parts. Let us know how it works out when your part arrives!
Old 04-06-2005, 08:07 PM
newtvdude
Guest
Posts: n/a
Yep! That is the part!
OUTSTANDING!
From my "minimalist" description, they got the part correct the first time! Thanks for the heads up, I'm sure that I'll be using them for many furture orders!
