Old 09-13-2015, 09:46 AM
OK the bad cap is C519 4.7mfd use a 250 volt or
more. Its off the cathode of CR506 & near the flyback.
I will keep the Sams out if you need more. Remember
this one, its one of the most common failures on any
brand solid state sets.
Old 09-14-2015, 08:33 AM
Adam's Avatar
Adam Adam is offline
Thanks for posting that. While there was no way I was going to find a whole day to spend searching around for the cause of this until December, I can probably manage to find enough time to just swap out that one cap. This semester is quickly becoming my hardest and busiest ever.
Old 09-14-2015, 11:32 AM
Sounds like you've got it rough. Remember once you graduate, you can take a good block of time off before diving into a career....That is what I've done with my summer this year.
Old 09-14-2015, 05:00 PM
Adam's Avatar
I've already taken my time off. I did an MA in ancient languages, then took some time off, taught a little bit, then decided to go back to the beginning and go for a BS in physics...
