Old 08-25-2015, 02:20 PM
turf1600 turf1600 is offline
Can anyone help me ID this Magnavox console?
I'm trying to find a schematic for this thing and I am struggling - I can't even find a picture of the same unit online. I also can't find a model number anywhere on the exterior.
Any help would be appreciated - and if anyone has worked on something similar tips are welcome.
File Type: jpg 11924928_10155945120255453_3106221601127666556_n.jpg (49.1 KB, 103 views)
Old 08-25-2015, 02:40 PM
Early 60's possibly a 24 or 27" tube?
Magnavox usually has numbers stamped on the individual chassis, usually on the rear apron, you'll probably have to look up the schematic based on that number since they used the same chassis in many different models.
Sams website has an index where you can look up the folder needed.
Once you know the number I would recommend buying one from eBay or someone here rather than pay full price from Sams for a PDF.
https://www.samswebsite.com/
Old 08-25-2015, 03:39 PM
DavGoodlin's Avatar
Motorola Minion
As Eric says, the chassis number is more reliable for Mags. It may be a two digit with a dash like "38-01" or such
If you have a model number, sometimes it is listed in a Sams index.
-Dave G
Old 08-25-2015, 08:45 PM
Also I've found you need to leave the dash out when you search using the Sams index. Just let and numbers and letters run together.
Old 08-30-2015, 12:46 PM
picture of the back showing the chassis would help.
maybe same as this
https://www.youtube.com/watch?v=GPZchjUlKzQ
