Old 10-26-2014, 12:11 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Good call. The horz osc is the 6JW8. BUT the horz hold coil is
delicate & they would get smashed in. Usually you can fix them
but we stocked them. windings are apx 15 ohms & 85 ohms.
May also have got pushed out of PCB. Thats it for easy stuff.
These Admirals were OK to work on, didnt like the older ones.
I just had the tubes out for a quick clean-up and chassis pic re-shoot, no 6JW8 in sight. The tube complement is as follows:
6KD6 horizontal output
6MJ8 (not lighting)
6BV11 (gassed out)
12HG7
6LU8
6LX8
6CG3
6KV6A regulator
3DF3 rectifier
6AQ5A (hiding behind power supply filter cans)
New chassis pics. I had to switch off full auto to make the camera flash and not blur the pictures, but I got rid of the custom white balance settings used for a pic I took long ago.
https://www.flickr.com/photos/spacec...57638419636316
Last edited by Jon A.; 07-10-2015 at 07:31 PM. Reason: Didn't notice the 6AQ5 until now.
Old 10-26-2014, 02:13 PM
This shows at least 2 Sams 1281 I have & another I dont.
Compliment I have
6KD6 hoz out
6LU8 vert osc / out
12HG7 video out
6MJ8 r-y, b-y, g-y amps
6BV11 demodulator
6CG3 damper
3DF3 HV rect in cage
6KV6 HV regulator behind cage
6JW8 horz osc. May be a production change or a sub. It is near the coil.
Old 10-26-2014, 03:29 PM
It appears that the 6JW8 and the 6LX8 differ *only* in heater current requirements:
http://www.radiomuseum.org/tubes/tube_6lx8.html
Should make no difference in a set with 6.3 volts supplied to the tubes from a power transformer.
Nice job of fixing the pictures!
Old 10-26-2014, 05:03 PM
Jon A.'s Avatar
Am I right in guessing that bad HV rectifier/regulator tubes will not cause CRT damage like bad safety caps in SS sets? That reminds me, I saw white caps under the chassis but I have no idea if they're safety caps.
Old 10-26-2014, 06:55 PM
No. Decapitation of the CRT from its neck due to excessive HV was unheard of in tube sets. It occured only in SS sets with the 4-legged "safety" caps.
When the cap failed, it allowed the HV to soar to 50 KV or higher, which exceeded the dialectric strength of the glass. Bleed-through resulted in thermal stress in the glass which sheared off the neck slick as a whistle.
Tube sets could only make 30 - 35 KV when the regulator failed, which wasn't enuff to hurt the glass.
In reading the tube complement of your set, I was hoping to see a HV regulator tube listed. Are you sure there isn't one lurking back there somewhere? If not, the set uses the nefarious feedback regulation setup which was very problematic. Hoping yours is an exception to the rule.
Old 10-26-2014, 07:09 PM
Not to worry. I dont remember much destroying a CRT in
a tube job. Only thing that may is arcing at the anode that etches
into the glass & cant to my knowledge be fixed. Seen that once.
Maybe a burning yoke could do it to.
White caps are always suspect & AFTER you know you got a good CRT
may be best to change them.
IMHO at this point the best thing is to get the HV up & see how
good the CRT is with minimal investment. Quick lesson
The hoz osc drives the horz out.
The hoz out runs "class C" so is turned off most the time.
If the horz osc is running OK there should be a large negative
voltage on the hoz out G-1 ( -75 VDC) on pins 5 & 9.
If the negative voltage is not there the tube is on all the time
& it will soon glow red & even melt but the breaker sees the
heavy current & pops. Thats the short story but things after
the H out can load it down & cause the same thing. Often
when you get it going the H out is weak or bad, usually width is
in but you can judge the CRT at that point.
6KD6's are used in home brew HAM amps so they bring a
premium price. Maybe if you need one a kindly soul on the list can
help, it was a very common tube..........
Old 10-26-2014, 07:41 PM
Jon A.'s Avatar
In reading the tube complement of your set, I was hoping to see a HV regulator tube listed. Are you sure there isn't one lurking back there somewhere? If not, the set uses the nefarious pulse feedback regulation setup which was very problematic. Hoping yours is an exception to the rule.
There probably is considering the tube lineup posted by zeno, but I haven't been in there far enough to check it out. I've only had the back off and the immediately visible tubes out so far.
By the way, I have an extra 25V pulled from a real basketcase that hopefully will work without too much trouble should the original prove weak.
Old 10-26-2014, 08:51 PM
rca2000's Avatar
rca2000 rca2000 is offline
I do not think so...the final "dense hybrid' color sets--with under 10 tubes--often did not use any regulator tube at all. Our beloved 4 tube Zeniths are a good example. Nothing much more than a VDR or 2 to control the voltage applied to a feedback ckt from the flyback--tied in the grid ckt. of the H-out tube. I suspect this is quite similar. By 71--NO set used a shunt reg. I think--and not nearly all used a pulse reg (such as the 6KV6 or 6HS5). By that time--mfg's were finding it easier to eliminate them--just using a vdr or 2 as the reg.element.
STILL my favorite--is the old reliable 6BK4 shunt reg. tube--as used in my 1969 or so Sylvania D-12 set--I think it has 9 or 10 tubes or so. FULL SS audio and IF. One is a shunt reg, one is an HV rect. Later sets that used triplers eliminated both of those tubes--such as the D-16 set.
Old 10-26-2014, 09:26 PM
sampson159's Avatar
sampson159
d 12?very,very good sets.those and the d 16 chassis sets were awesome.love to have a few of those now
Old 11-01-2014, 02:15 PM
Jon A.'s Avatar
Compliment I have
6KD6 hoz out
6LU8 vert osc / out
12HG7 video out
6BV11 demodulator
6CG3 damper
After digging a little further, I'm pleased to report that this set uses a 6KV6A regulator and a 3DF3 rectifier. I doubt that the regulator's "A" suffix means much at all.
By the way, is it safe to power up with missing tubes? The 6BV11 is toast of course, and I'm hoping that I can check for those negative voltages with the hoz out removed.
I updated my tube complement list in post 16.
Old 04-11-2015, 01:42 AM
Jon A.'s Avatar
Well, I finally got to test the CRT. Low emission on all three guns, the red gun being especially bad. Also, it's had a lot more use than I first thought; I discovered a lot more black dust, so instant play is not totally to blame for the CRT's condition. I know just about all delta-gun CRTs are electrically the same, but which ones will sub directly for a 25VABP22?
I finally noticed a switch next to where the power cord goes in. No indication as to what it does, it's simply marked "on/off". It can only be accessed by removing the rear panel. I'm hoping it disables instant play.
I discovered a cracked resistor, R545 near the horizontal output tube.
Old 04-11-2015, 01:14 PM
My sam's sub manual lists:25VADP22, 25VAJP22, 25VALP22, 25VAMP22, 25VBMP22, 25VCGP22, 25VCKP22, 25VDAP22, 25VDEP22, 25VDXP22 as subs.
This manual likes to cross 3 letter tubes to 3 and 4 letter tubes, but to only cross 4 letters to 4 letters. If you have a spare 3 letter type I can try to cross it forward to a 4 letter type and see if that crosses back to a 25VABP22.
Old 04-11-2015, 03:44 PM
Jon A.'s Avatar
Thanks for the info. Unfortunately the only good spare I have is a 19" inline.
Old 04-11-2015, 05:25 PM
BTW are you aware of the phenomenon of CRTs being asleep? In a nutshell if a good tube is not used for a few years gas inside the tube gathers on the cathode and forms a coating which blocks emission. The coating can be boiled off if you run the tube heaters at 1.4X their rated voltage for about 10 minutes give or take. Any weak tube that I don't know the full history of gets the 'cooking' treatment before I write it off...And most bounce back well.
Old 04-11-2015, 11:24 PM
Jon A.'s Avatar
I have heard of it but didn't know anything about it. I did hit all guns with auto-restore more than once but it didn't bring satisfactory results.
Another thing that I had never seen before in a tube that was still under vacuum: the phosphor coating looked, for the lack of a better word, uneven around the middle of the screen. I cleaned it, no difference.
