Old 02-02-2015, 10:44 PM
Gregb Gregb is offline
The chassis number is C817.51480, if anyone has any service data it would be greatly appreciated.
Thanks
Gregb
Old 02-03-2015, 12:24 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Greg,
Went thru my Sams Photofact Index looking for your chassis #. There are pages & pages of Sears-Silvertone sets listed. I did not locate that chassis #.
Seeing your location, could it be that your set is a Canadian manufactured set?
-Steve D.
Old 02-03-2015, 12:47 AM
Thanks for looking Steve and yes it was manufactured in Toronto Ontario Canada.
Gregb
Old 02-03-2015, 09:55 AM
Gregb
Is there still a Simpson-Sears presence in Canada?
The chassis might still be a Warwick design. The record changer might've been changed at one point.
Maybe a picture of the chassis, would help!
Old 02-03-2015, 08:10 PM
Simpson Sears is still here. I don't see Warwick anywhere on the set but there is Silvertone all over it. I have no doubt at all that the record player is original to the set. I see this turntable in numerous different sets with different names on them but they are all the same.
Here are some pictures of the back of the chassis, the turntable, and the audio amp and speakers.
Gregb
Old 02-05-2015, 06:01 PM
BUMP, anyone have any service info on my new find?
Thanks
Gregb
Old 02-05-2015, 08:33 PM
Thanks
Gregb
The chassis looks like the typical Warwick Silvertone. It looks like a few of the caps and transformers are of Canadian manufacture.
BTW, what are the tubes in the small stand-alone amplifier. IIRC, the set, I remember, used the audio output stage for the TV for the mono phono.
Old 02-05-2015, 08:58 PM
Olorin67 Olorin67 is offline
Its normal for canadian market units to have british changers. Even RCA used Collaro or BSR changers in its products sold in Canada. It was cheaper to import them than ppay import duty on USA made changers. Looks like yours is a collaro, better quality than the usual Silvertone changers which were made by Crescent, I think.
Old 02-05-2015, 10:29 PM
The tubes in the little amp are a 12AX7 and a 6AS5. The turntable has a stereo cartridge in it and there is an extra jack just out of sight in the amp and speaker picture that is marked "Stereo".
The amp is only connected to the large speaker, the small speaker is wired back to the TV chassis.
Gregb
Old 02-06-2015, 12:40 PM
BigDavesTV's Avatar
BigDavesTV
Gregb, I just saw this, and your TV Chassis is just like the one in my Silvertone, looks identical! So if you P.M. me your email, I can help you with a Schematic, for the TV chassis at least. Those Collaro Changers are well made, and usually only need the old lube cleaned out, and re-lubed with the proper Lube, and sometimes on that Collaro, I've seen the Speed Selector assembly frozen from solidified lube, you must then clean ane re-lube that assembly if that's the case. Dave, "BigDavesTV"
Old 02-06-2015, 05:28 PM
Gregb
The 6AS5 is a low B+ tube, similar to a 50C5. It looks like they're running it at slightly higher plate and screen voltage, as the 'lytic is a 200 volt cap.
Probably an honest 3 watts.
Old 02-06-2015, 05:35 PM
I really look forward to getting this one going. The Collaro changers are nice, I have a couple of them and they work great. It will be interesting to hear what the sound quality of this guy is.
Gregb
Old 02-10-2015, 11:50 PM
RobtWB's Avatar
RobtWB RobtWB is offline
... interesting
have the same Suburbanite b/w console in storage ... havent looked at it in ages ...
do remember it does have vert. roll ... have original manilla envelope with all the usual sales literature manual etc.
Old 02-11-2015, 10:14 AM
I saw one of those RCA "International" German built, radio-phono combinations. Looks like the typical German console, large glass multi-band dial scale, large white push buttons, ETC.
The changer was the usual RCA changer, we're so familiar with. Go figure!
