parents honeymooned in Q City, the set goes well with the pictures they brought back. Some awesome architecture. Only been to Montreal myself & it dont hold a candle to QC from what I seen. 73 Zeno
It's paper, and my only one. 87 pages, not an easy scan. Lots of good info, I'll see what I can do.
Cheers,
That set looks like Zenith's "The Chaumont" or "The Palma", as listed in a 1971 Zenith TV brochure I downloaded as a PDF file. I believe this file is still available from Mediafire.com, although you may have to search VK's archives to find it. VK member Doug, drh4683, scanned a bunch of those brochures onto MF.com; they are probably still there.
Hi Jeff... Do you have the link please?. thanks |
Thank you for the comment.. However I only need the schematic for the complete circuit. I'm sure I'm not learning you anything but mine is metal. . Anyway. do your best |
Sams is # 1266...
I pulled the manual on this set. When you open it
look on the side of the flyback transformer. There are 2 capacitors marked 22-5001 .0018 1.6 KV. ( D & E chassii have more). If they are white you must change them. If they are orange they are OK to use. The HV tripler should be examined for cracks. The focus divider is the "rocket ship" style & rarely gave trouble in Zeniths. I will keep the manual handy if you have other questions au revoir Zeno
![]() PS: If i clic 'ON " i can see the picture but not complete. the sound is great and I do not hear crackling from inside the cabinet and the flyback .. There are no tubes either on the frame. In french : Je vois les trois quarts de l'image dans l'écran mais les têtes des personnages sont difformes et sont penchés vers la droite.. |
Flat chassis refers to the way it is laid out...on a relatively FLAT metal frame. built MUCH like a tube set--but solid state. The 3 model years of flat SS chassis (along with the 4 tube hybrid sets from the same time frame, also a flat chassis construction) happen to be what many of us consider THE BEST tv sets EVER made--bar NONE.
As for the safety caps---they are on the flyback board. If white they WILL need replaced. If they look like an " orange tubular blob", known as [orange drop" they are likely OK. |
I guess those C-line flat chassis don't give as much of a grace period for CRT survival, if any, when a white safety cap opens.
If I understand, I have a quality Tv isn't it? |
I wish I had one ! Sorry only remember a few French words from my lessons 50 yrs ago. There are other members in PQ that may help you. American English can be very hard because we have so many accents. Northern New England is the only place that does not have an accent ! 73 Zeno
