You could try shimming the bad tab with something (I've used thermal transfer pads, others recommend rubber tubing) so that it is kept under enough pressure to make connection.
I don't consider this a proper repair, but it may get some more life out of a set that would otherwise be scrapped.
I remove the front panel, then place it on it's back with the screen facing up. Then remove the frame to expose the tabs. Power the set up and press on each tab with a finger tip looking for changes in the picture. There are probably videos on Youtube showing the process more clearly than I am explaining it.
