Old 10-01-2014, 12:48 PM
Murphu222 Murphu222 is offline
Sony BVH 500
Hi, I just found a Sony BVH 500 "portable" one inch recorder. I was wondering if anyone has ever been able to connect it to a TBC without having the playback adapter? I have the pin outs of the connector but thought I would check here to see if anyone has ever tried it. Also, I am looking for the playback adapter, either the Sony HT 500 A or the CLP 550.
Thanks,
Murphy
Old 10-02-2014, 11:42 AM
mpatoray's Avatar
mpatoray mpatoray is offline
What is the pin out of the connector?
I am sure a break out cable could be made for connecting to a standard TBC. The color playback adapters are quite rare.
Matt
Old 10-03-2014, 04:46 PM
Here it is.
Old 10-07-2014, 10:55 AM
Am I correct in thinking I would have to feed sync in from the TBC?
Old 10-07-2014, 11:10 AM
mpatoray's Avatar
Your TBC should have an Advance Sync out, which you would feed into the VTR, the RF would go to the RF in onyour TBC.
I am going to see if I can come up with a connector for that plug (I think there was an edit controller that used the same one) and I will try and make up a cable.
Old 10-07-2014, 12:37 PM
Tim's Avatar
Tim Tim is offline
If you cannot locate a mating plug, I believe I have one new in the package I can send to you. It is just the plug with housing and cable clamp, no cable.
Tim
Old 10-07-2014, 08:50 PM
Dave A's Avatar
Dave A Dave A is offline
Thanks for the pinout. I have the RCA version of this deck and this is a big help. I have a Prime Image TBC that has all the ports. Now for the connector and getting my deck to move forward. Shuts down on play.
Old 10-08-2014, 09:44 PM
Tim's Avatar
Tim Tim is offline
Unfortunately, the plug I have that I thought was 24 pins is only 20 pins. Sorry I can't assist.
Tim
Old 10-15-2014, 05:08 PM
Thanks for all of the information. One other question, I was wondering if I could use a Betacam playback adapter? I have seen a few models that have sync and reference connections. Again, thanks for all you help. If I ever get around to playing with my TCR 100, I know where to go for help!
