Old 12-31-2013, 04:26 PM
rose14 rose14 is offline
Now that most of the tv shows and sports are shot in 16x9 formats,if you dont put your tv in that aspect ratio alot of picture information is lost.With sports that can be important game information. Does anyone find that going 16x9 with the black bars on the top and bottom of the tv make the picture too small on 27'' or 20'' sets? Also does anyone find the black bars distracting? My 20'' set becomes very small when I go 16x9 ,but I miss the sports info if I leave it 4x3. Thanks for any comments.
Old 12-31-2013, 04:45 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Comment:
I like the old RCA more than I care about the black bars... I see it as one of the concessions one needs to make to keep using 50 year old technology on a day to day basis. Would be great to have a screen filled with picture, but those days are gone, may as well be happy with the fact that the old TV can be used at all! Also, my TV has an annoying red purity issue exactly where the top black bar is, so all is not bad!
Old 12-31-2013, 05:44 PM
TVTim's Avatar
TVTim TVTim is offline
I do.
Have five TVs hooked up. Four are good old CRT.
The one Sony Bravia flatscreen is used the least believe it or not!
Old 01-01-2014, 01:18 AM
Countryford's Avatar
Countryford Countryford is offline
We only have two flat screen tvs in the house. One is in the kitchen in a cabinet. My partner can watch tv while he cooks. The second one is hanging on the wall outside under the back patio. The only reason for it, is a CRT would be too big and heavy to hang on the wall. That one is a 42".
In the living room is a 1959 Magnavox B/W TV. The den is a late 70's Zenith console. The bedroom has a 1956 Philco B/W TV.
Old 01-01-2014, 02:09 AM
Originally Posted by maxhifi View Post
Comment:
I have the same problem with black borders on the picture of my Insignia 19" flat screen TV. The set is an LED-LCD one so I don't have to worry about image burn-in, although I will say it is a bit annoying to watch certain channels (PBS World, for one) with the black spaces above and below the picture. My set has an "auto zoom" option on the video menu, so I was able to set the aspect ratio such that most stations' video appears to fill the screen. Ordinarily I wouldn't worry about the zoom, but I watch one cable channel (USA Network) every once in a while and some of its programs appear with black spaces above and below the video. My TV has the "zoom" button on its original remote, but I just don't like the idea of having to drag that remote out of hiding just to zoom in the picture (I use a GE universal remote to control the set, using the original Insignia remote only to get special functions such as zoom, menu options, et al). However, I guess I'll just have to get used to having to grab that original remote every now and then, when an image appears on my screen with those black areas above and below or on either side--or even when the image appears as a small square on the screen (I've seen the latter more than once since I've had my flat screen TV). That square may be the result of the image being cropped both ways, vertically and horizontally, but I'm not sure why this is done. Maybe that's the beginning of so-called "4K" ultra-HD, with the picture showing as normal on a flat screen TV designed for either 4K or ultra-HD video, but squarish on ordinary flat screens?
Old 01-02-2014, 11:58 AM
Phototone Phototone is offline
I regularly watch my 60" Mitsibushi rear projection CRT HD TV. Got a little burn-in from watching news channels too much, but otherwise a great picture.
Old 01-02-2014, 05:49 PM
sampson159's Avatar
sampson159
i had a mitsubishi 70 inch set for years.that was a great unit and the picture was spot on.sold it on ebay and actually got almost the original cost for it after 8 years of flawless service
Old 01-07-2014, 12:03 AM
john f john f is offline
I've got a 1991 Sharp Linytron model 19rp519 that was our main TV when I was growing up. It was retired to bedroom duty when it developed a kind of flickering white line at the top of the picture, almost like the vertical is a touch too short. Even with the line, it outlasted the BPC set that replaced it. Still has a nice picture even though there's a ton of hours on it. (The white line is visible in the first picture.)
Old 01-07-2014, 12:34 AM
That line looks like it could be closed captioning. I'd take the back off and look for vertical height and linearity controls to increase vertical over-scan slightly to see if I could move it off screen.
Old 01-12-2014, 10:18 PM
uncleputz uncleputz is offline
I use a '73 RCA XL-100 27" console in my "laboratory", a 1992 RCA Home Theater 27" console in the living room and a 1996 RCA Home Theater 36" console in our family room. We will watch our old CRT sets until we can't get a signal to them. We have been wondering when they will die, but they will probably outlast us! The only thing that has been done to any of them was to the XL-100. I had to replace the power switch. In 1982.
Old 01-14-2014, 07:17 PM
crh4881's Avatar
crh4881 crh4881 is offline
Old 01-14-2014, 07:29 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Originally Posted by crh4881 View Post
I have a 19' 1976 Zenith Chromacolor 2 as a daily viewer Attachment 181349
Ooh, gotta love it.
My current viewing setup. The rabbit ears are just for show, they're not hooked up.
Dangit, how did my picture get rotated?
Old 01-14-2014, 07:53 PM
Old TVs are better!
I have several old CRT TV's that I have restored and watch them from time to time. I watched a full dateline broadcast just recently on my CTC9 RCA. Also have watched a couple of hours of programs on my 1953 Sylvania Halolight while working on other sets, and stuff in my shop area. An interesting thing at my work, since I work at a fast food restaurant (since I retired from TV repair) is that they still use a Toshiba CRT television for the drive through monitor. It's left on 24 hours a day and has been going working at least 8 years now. Must admit I usually watch my 50 inch plasma as my main TV in the family room, but do love the CRT TVs, as I suppose it's the type of TVs that I grew up with.
Old 01-14-2014, 08:16 PM
crh4881's Avatar
Originally Posted by KV-1926R View Post
Ooh, gotta love it.
Hey that's like my old RCA before I got the even older Zenith, it worked really well for me nice set.
Old 01-14-2014, 08:56 PM
TVTim's Avatar
Ooh, gotta love it.
That is just like the RCA I want to get.
