Old 12-26-2013, 10:32 PM
pac.attack76's Avatar
Stuck in the past
Originally Posted by TVTim View Post
The knowledge on this website is fantastic!
It sure is. Zenith is tough!
Old 12-27-2013, 08:24 AM
Nice work, I knew you could do it ! If that CRT is good
you will be treated to a real fine pix.
Now go get another set & we can have more fun !!!
Old 12-27-2013, 10:01 AM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Congrats! Those 80's set deserve to be saved as much as those of the 70's or the 60's in my opinion! Be sure to keep us posted about your cabinet restoration also!
Big thanks to Zeno on this one also!
Old 12-27-2013, 01:55 PM
Stuck in the past
I Agree. They should be saved. colors seem a bit rich though. especially, red and blue. all colors show up well on everything and the clarity is good. watched several movies on it last night. Hopefully, i'll start on the cabinet after spring.
Old 12-28-2013, 01:49 AM
Stuck in the past
I don't have any other non working sets other than a Sony Trintron Wega 24" from around 2002 that has an issue with the bottom half of the screen pulled up. looks like its folded. bottom half is blank. upper half is normal with lines. check out my post on it snd its model number.
Old 01-03-2014, 02:49 AM
Stuck in the past
Here are 2 remotes i have. Both use the j battery. One is for this tv.
