Old 11-19-2010, 12:31 PM
The burlap looks much better after washing, with the tighter weave. I wouldn't have used it without the processing ("What's that -- an old feedsack?"). Now it might pass the six-foot walk-by test.
Phil Nelson
Old 11-19-2010, 02:52 PM
Reece's Avatar
Reece Reece is offline
We ain't tellin.
I'm a real scrounge.
Reece
Old 11-19-2010, 09:19 PM
Well it's not something I'll be bragging about, but it'll do for now.
I glued the left edge and let it set up. Then applied some glue to the rest and used a pants hanger plus weight to stretch it across.
Old 11-19-2010, 10:14 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
Looks great!
Old 11-19-2010, 11:58 PM
kvflyer kvflyer is offline
Looks good Bob.
Old 11-20-2010, 01:01 AM
Thanks guys. Here it is back together.
I suspect I need some rubber mounts under the chassis. The CRT and knobs seem a little low.
Ugh. A few specks of dirt fell between the glass the cabinet.
P.S. the GE 212 arrived safe and sound today
Old 11-21-2010, 03:42 AM
I got a tip that some European radios have similar grille cloth. I took a look over at grillecloth.com and, sure enough, pattern #62 Silvertone, Grundig looks like a good match. 16 X 25 should do the trick.
Old 11-21-2010, 04:49 AM
Bob, that set has a great picture but yeah, that Burlap has to go.
It reminds me of this :
Old 11-21-2010, 02:03 PM
Reece's Avatar
Aw...I like the burlap, and the ignition transformer!
Reece
Old 10-17-2013, 07:04 PM
Here it is three years later and a few issues have come up.
  1. The finish on the top of the cabinet developed small blisters. Likely because I ran the set with a radio on top and a small towel between that trapped the heat.
  2. The horizontal and vertical hold became extremely touchy.
  3. The picture became dim.
So I've been re-restoring this set for the past few weeks as some of you may have seen in my YouTube videos.
First I re-refinished the cabinet using Constatine's grain filler instead of shellac this time around.
Then I tackled the hold issue and quickly found the hold control was rotted out. Not the easiest control to find.
Amazingly, I found a beat up "barn fresh" GE810 less than 50 miles away on eBay at a reasonable price
I kept my fingers crossed and got lucky. Not only is the hold control good, the 10FP4 CRT is excellent. That's the "new" chassis on the left.
I was also able to salvage the grille cloth so say goodbye to the bleached canvas I also repainted the mask gray rather than green.
Note I'm currently working on that frame and it will look a lot better with all the grain filled it.
Old 10-17-2013, 07:08 PM
So I swapped out the control and eventually figured out the picture was dim because of a bad 5V4 damper tube.
That leads me to my current (and hopefully last) issue - some wavering at the top of the picture.
I've tried adjusting the horizontal oscillator coil, osc. trimmer cap and hold control. They all have a very minor effect, but not enough to make it go away.
Any thoughts ?
Old 10-17-2013, 07:16 PM
egrand
Guest
Posts: n/a
I've been following the saga on youtube (as I do with all your sets) and I do like the cabinet a little better this time around.
Spoiler Alert: I know you had lots of issues that turned out to be tube related. How much of all the problems do you attribute to coincidence or do you think that just sitting and aging had something to do with it?
Old 10-17-2013, 09:51 PM
That's hard to say. I think I used some DeOxit on the hold control three years ago and that may have slowly affected the carbon or perhaps it just finally wore out. Likewise, maybe I just had some bad luck with the 5V4 or it went bad at the same time
Old 10-17-2013, 10:17 PM
Very nice re-restoration. That makes good sense that DeOxit could have eaten the carbon track, especially if it was wearing very thin. I'm not too sure how that stuff can decipher between oxide and carbon. Think I'd rather use some sort of wash followed with lubrication spray on dirty carbon controls.
Old 10-17-2013, 10:31 PM
Thanks. I'll post some photos of the cabinet soon. I'm very happy about the grille cloth
I didn't dare try to do anything to the "new" control. Now that the sync is pretty solid I don't think it'll need much adjustment anyway.
My backup plan was to leave the bad control mounted with the knobs for appearance and hide a control somewhere inside
