Old 06-15-2013, 07:16 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by VintagePC View Post
Are there any problems with this method?
Works fine, as long as you you stay within the voltage and current ratings of the transformer.
The problem is the current ratings were probably not determined for this off-spec use, so verify that the transformer stays at a reasonable temperature.
James
