Old 03-24-2013, 09:03 PM
chipper chipper is offline
13de7
I have a Heathkit tube tester and can someone give me the setting to test this tube?
Old 03-24-2013, 09:24 PM
snelson903 snelson903 is offline
what is your model number of tube tester .
Old 03-25-2013, 06:34 PM
Model tc-2
Old 03-25-2013, 07:10 PM
its not on my tc-2 chart ,unless there is a updated chart at one of the heathkit websites ,the tube might be newer than the tester.
Old 06-26-2013, 05:37 PM
wkand's Avatar
wkand wkand is offline
13DE7 TT Settings
On thing you might try is looking in the Heath guide for a "DE&" tube with a differnt first number (filament). The first thing Id try is 6DE7. the settings should be the same except for filament voltage, which should work at 12 volts if the testerdoes not have a 13 volt setting.
Old 06-26-2013, 05:38 PM
wkand's Avatar
13DE7 TT Settings
On thing you might try is looking in the Heath guide for a "DE7" tube with a differnt first number (filament). The first thing Id try is 6DE7. the settings should be the same except for filament voltage, which should work at 12 volts if the testerdoes not have a 13 volt setting.
