Old 03-18-2013, 09:13 PM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
Originally Posted by holmesuser01 View Post
Let it dry out for awhile.
Any idea how long it's been since it was last turned on?
A VARIAC is good for soft-starting electronics.
There are probably some bad capacitors to deal with here.
The 'massive tube'... Do you mean the horizontal output? How do you know it's burned? If you're seeing a dark spot on the side of it, that's probably normal.
Do you possess a tube tester? Anything for servicework?
You know anything about the flyback on this chassis?
