Old 02-17-2013, 06:51 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Congrats Looking good, must be satisfying to seeing a stable picture on it, CRT looks healthy too!
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 02-20-2013, 12:54 PM
ggregg's Avatar
ggregg ggregg is offline
I think I'm going to have to pull the sweep/ps chassis again. Something is pulling down the HV a little. Can't quite fill the screen, worse on right than left. Pin cushions seem fine. Swapped out the 1B3, Damper, 12DA6, and anything else related to horizontal, no change. Width control is a slug and works somewhat but even at max range doesn't fill the edge.
Old 02-21-2013, 12:40 PM
DavGoodlin's Avatar
Motorola Minion
Do you need a schematic?
I have the factory one issued through Electronic Technician Magazine "circuit digest" which shows a rather simple horiz sweep ciruit with voltages and waveforms.
I assume yours is model 21C529 or similar with 1-541 chassis.
Old 02-21-2013, 03:33 PM
ggregg's Avatar
I've got one, just haven't dived into it that far yet. Basically just a complete recap at this point. Thanks though.
Old 03-22-2013, 03:35 PM
ggregg's Avatar
Played with the pincushion magnet on the one side and am able to pretty much eliminate the problem but the other side adjusts much easier. Can the magnet be a little weak on the one side? It was adjusted further in even before I adjusted it more. Have a little teeny tiny bit of a curve on the right side but was able to get it almost straight and still keep the picture full. Played for three hours and it's still fine.
