Old 12-14-2012, 04:30 PM
AUdubon5425's Avatar
Need Advice Re: Heads
Last night I was working on my Canon VR-HF600 (Panasonic) VCR - the grease had gummed up in the loading mechanism and I disassembled and cleaned it well and relubed the gears. There was a little drag with the arms that stretch the tape over the head. While applying a little grease to the track I got a dab on the head drum itself.
Good Grief.
I cleaned it with alcohol immediately, but it appears the damage is done.
Is there anything else I can try? If not, where can I get a replacement head drum assembly for it? I called MCM but they said they no longer sell them.
AUdubon5425 Youtube Channel
Old 12-14-2012, 07:34 PM
Dangler's Avatar
Dangler Dangler is offline
You might try a little contact cleaner on a Q-tip. I used to use a really soft bristle baby tooth brush for really stubborn ones. Never had one damaged using it. It might take several cleanings.
I also used a good quality head cleaning tape afterwards.
" I'm gonna fix that one of these days"
Old 12-14-2012, 11:46 PM
Thanks for the advice - I'll give it a try tomorrow. It did play fine until my little fumble so I am hopeful.
Old 12-15-2012, 08:54 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Have no fear. I've cleaned up much bigger messes than that. Naphtha aka lighter fluid ought to clean off that grease. Clean it a few times. Then 1st tape you try should be one you can dispose of if it sticks to the drum, should not be an irreplaceable tape.
Old 12-15-2012, 06:10 PM
Thanks Ed - I may have some Ronsonol in the shed. I may not get to tear into it until Tues. or Wed. but will let y'all know what happens.
Old 12-20-2012, 12:00 AM
jmm83 jmm83 is offline
if you can't fix it i have seen one on e bay but its missing the door where the controls are.
